Dear Experts,
Currently, I am working on the Agilex F-series Transceiver-SOC Development Kit with EMMC Flash as the booting device. I am using Poky (Yocto Project Reference Distro) 4.1.4 agilex_fm61 with the console connected to /dev/ttyS0.
The challenge I'm facing is that I can't seem to achieve autologin and get rid of the login prompt. I have made changes to the /etc/inittab file, but the desired result is still not being achieved.
Could anyone please guide me on how to properly set up autologin and eliminate the login prompt on the Agilex F-series Transceiver-SOC Development Kit?
Your valuable assistance would be greatly appreciated.
Thank you in advance.
Raju Satrasala
Hi @mabdrahi ,
After the discussion with the Intel Team,
I have find a way for autologin and it is working as expected.
Thanks & Regards
Satrasala Raju
HI Raju,
If you are using systemd, in the file meta/recipes-core/systemd/systemd-serialgetty/serial-getty@.service change the ExecStart in the service to this :
ExecStart=-/sbin/agetty -a USERNAME -8 -L %I @BAUDRATE@ $TERM
try change USERNAME to root or other.
Hi Raju,
Any update from your side?
Hi @mabdrahi ,
Thanks for the response.
As per your steps,we attempted to update systemd using the following command:
ExecStart=-/sbin/agetty -8 -a root -L %I @BAUDRATE@ $TERM
Despite this update, it appears that the system is still prompting for the password,
indicating that the issue has not been resolved yet.
Thanks & Regards
Satrasala Raju
Hi Raju,
I will try to give you best solution and i will check it at my end
Hi Raju,
Can we make a call about this?
Hi @mabdrahi ,
Sure, we can have a discussion via Microsoft teams. Let me know at what time we can have a call.
Thanks & Regards
Satrasala Raju
We will use team as meeting invitation and discussion there
Here is a another link for baremetal application that may help you to toggle led
If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
Hi @mabdrahi ,
Thanks & Regards
Satrasala Raju
