570 Discussions
SoCEDS version 19.1 bsp-editor does not show spl as supported type
Ozzuu
I have installed SoCEDS version 19.1. BSP-editor does not support SPL, why is that? I have Quartus prime lite version 17.0 installed and I have checked the environment on embedded command shell, it finds the Quartus path correctly. Embedded shell output when tried to check supported types is as follows.
$ bsp-create-settings.exe --type \?
Available BSP types are: [uboot, uefi]
EBERLAZARE_I_Intel
Are you referring to the Standard or Pro version of the SoCEDS 19.1?
Ozzuu
EBERLAZARE_I_Intel
I apologize for the delay in response, checking our Soc EDS 19.1 release notes:
U-Boot, UEFI, and Arm* Trusted Firmware (ATF) are no longer part of Intel SoC FPGA EDS, but are available on GitHub.
For more information on the SoC EDS 19.1:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rn/rn_soc_eds_std.pdf
Let me know if you need more help!
EBERLAZARE_I_Intel
Do you have additional questions?
