573 Discussions
Unable to Compile FPGA-to-HPS Bridge Design Example for CV SoC DevKit Rev E baremetal project in Eclipse on Windows 10 Machine.
MHada
I downloaded the following project for Cyclone V SOC Development Kit:-
and programmed the FPGA using .sof file on my kit which is done successfully.
However, when I try to compile the software project in eclipse on my Windows 10 machine, it gives the following error attached in the image file.
Why is such error here? How do I remove this error?
MHada
I am unable to find cycloneV_hps_arm_a9_0.h
Where can it be found? Please inform.
Also please let us know as to why this problem is coming?
EBERLAZARE_I_Intel
Can you rebuild the project by following the steps below from page 26 to page 29:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_soc_eds.pdf#page=26
EBERLAZARE_I_Intel
Have you try rebuilding the project following the steps above?
I did face the similar error when using a prebuilt project, thus I attempt to rebuild the project and it does removes the error.
