573 Discussions
Unable to access FPGA_bridge_lwsoc2fpga_2M Address Map from Uboot
binupr
New Contributor II
Hello there,
We are having issues accessing the FPGA LW address map from Uboot. This is for Intel Agilex SoC. Qsys has the LW bridge enabled. We are also enabling this bridge via CONFIG command in Uboot. Is there a specific setting in device tree or .dtsi file for enabling the light weight bus?
The issue is that when we tried to read or write from any address aligned space on 0XF9000000, Uboot hangs.
Any advice on this is much appreciated.
Binu
JingyangTeh_Altera
Hi Binu
So sorry for the late response.
You could use the md command, no need the axi md.
For the example you could take a look at this dtsi.
https://github.com/altera-opensource/u-boot-socfpga/blob/a08598d99fe40f5214922d30da9af9ef7a43f2fd/arch/arm/dts/socfpga_soc64_u-boot.dtsi#L4
Jingyang, Teh
JingyangTeh_Altera
Hi
In the uboot environment have you successfully loaded the FPGA configuration?
If yes, you could use the command "bridge enable" to enable the bridges before accessing over the bridge.
Jingyang, Teh
binupr
New Contributor II
Yes the FPGA configuration was successful. And yes we have enabled bridge using bridge enable command.
There has been some progress but that is only after adding lightweight bridge information in uboot device tree. But even with that we are not able to get correct information via ‘axi’ cmd for address space 0xf9000000
JingyangTeh_Altera
Hi
Yeah, the bridges will needed to be added into the device tree as well.
You could refer to our GSRD for the device tree example in the link below:
https://github.com/altera-opensource/u-boot-socfpga/tree/socfpga_v2023.04/arch/arm/dts
What is the axi command that you are referring too?
In uboot you could use the md tool to read through the bridge.
Jingyang, Teh
Jingyang, Teh
binupr
New Contributor II
Can you point from the above link which dtsi are you referring as there are bunch there for different processor target?
The axi command we are using is "axi md 32 0xf9000000"
BPR
binupr
New Contributor II
Hi Jingyang, Teh,
Any feedback on my above question?
Binu
binupr
New Contributor II
Hi Jingyang, Teh,
Following up on the above question.
Should we be using 'axi md' or 'md' command in uboot to access AXI light weight bridge?
Binu
JingyangTeh_Altera
Hi Binu
Jingyang, Teh
JingyangTeh_Altera
Hi
Any update on this case?
Is the md command working on your end?
Jingyang, Teh
binupr
New Contributor II
Hi Jingyang,
Yes md command is working for us.
Thanks for the recommendation.
Binu
JingyangTeh_Altera
Hi
Since this thread been resolve, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, some one will be right with you. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 4 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
