572 Discussions
alt-boot-disk-util v20.1 returns "Device open failed" error
FilipMiler
Hi. In SoC EDS version 20.1, the alt-boot-disk-util SD card utility doesn't work, it always returns "Device open failed" error message regardless of running as administrator, specified destination drive etc.
alt-boot-disk-util from SoC EDS version 18.1 works fine on the same computer.
JingyangTeh_Altera
Hi FilipMiler
Could you try starting the Embedded Command Shell with Administrator Privileges before trying invoking the "alt-boot-disk-util" exe?
Which board are you working on currently?
Jingyang, Teh
FilipMiler
Hi. Yes, I'm starting the shell with administrator privileges. alt-boot-disk-util from EDS 18.1 works fine in command prompt shell, but version 20.1 doesn't.
Filip Miler
JingyangTeh_Altera
Hi
Any update on this case?
Jingyang, Teh
JingyangTeh_Altera
Hi FilipMiler
Since there are no feedback for this thread, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, someone will be right with you.
If you happened to close this thread you might receive a survey.  If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
