449 Discussions
alt_qspi_read() QSPI addressing problem
MCOUNSELL
alt_qspi_read() is returning data from the QSPI address -1. I've written data to the QSPI by two different methods. quartus_hps.exe and also using alt_qspi_write function it in both cases the data from QSPI is returned out by 1byte address.
I am using the Altera Cyclone V dev kit.
QSPI is setup in PlatformDesigner as per the GSRD examples.
I have debugged through the alt_qspi_read() code and I cannot see any obvious "out by one" issues.
The hardware must be OK I assume since the preloader runs correctly from QSPI and loads my bare metal application and runs it.
The problem is quite easy for me to work around BUT I'm worried that it is the sign of something bad elsewhere!! Has anyone seen similar?
Intel? Can you comment please?
EBERLAZARE_I_Intel
Did you run into any error when writing the data via quartus_hps.exe?
MCOUNSELL
No, writing via quartus_hps.exe is perfect. Never seen any errors and I have written many many times using this exe.
Mike
EBERLAZARE_I_Intel
I assume if there was no error when booting up the board such as bad u-boot.img etc or anything that prevented the board from booting, everything should be fine.
JEkla
Having the same issue. We are reading an image that was programed with quartus_hps.exe and data read with alt_qspi_read is shifted 1 byte.
MCOUNSELL
Hi JEKla,
I'm kinda pleased to hear that it's not just me..... maybe we'll get more help from Intel in this case....
What h/w are you using? Are you on the Intel/Atlera dev board?
Mike
JEkla
We are using a board that’s is designed using Cyclone V SX SoC development kit as reference. Our software tools are Quartus Prime Lite 17.1 and Intel SoC FPGA Embedded Development Suite 14.1.
MCOUNSELL
Are you using the same QSPI IC on your board?
JEkla
We are using N25Q512A83GSF40F.
MCOUNSELL
I see, that's the same IC as I have on the Dev Kit board. My gut is that the Altera C code is to blame rather than the IC/board...... something in the QSPI indirect read code............. but no comment yet from Intel/Altera....
I've worked around the issue by adjusting the requests into alt_qspi_read(). I wrote a wrapper around this function and I read to address -4 with size +4. Hence I read the preceeding 4 bytes also.... then I pull out the data that I really want........ it's a total HACK of course but it is a reliable HACK for now until I find out the real source of the issue.
@INTEL ----- please give us some more input guys/girls.... your FPGA SoC is awesome.... loadsa folks wanna make solutions out of it and give you loads more money for these ICs but you really need to support us better..... pleeeease
JEkla
We are also stuck with a workaround solution for the moment.
MCOUNSELL
Forgive me if I'm telling you something that you already know here but you have to word align your read requests in your workaround....... Hence you cannot read address-1 as a work around.... you have to read address-4 -- to the end of where you want to read and then copy the data out of the buffer....... forgive me if I'm teaching grannies to suck eggs 🙏
Good luck
Mike
EBERLAZARE_I_Intel
May I know which Quartus Version and SoC EDS that you are using?
Regards.
MCOUNSELL
HI
Quartus Prime Lite Edition v18.1.1
"Intel FPGA 18.1.0.625
