公告
573 讨论
error when debug an exercise sample application on A10 SOC board
Rainwang
新分销商 II
3,479 次查看
hi,
i faced another error.
My PC environment:
virtual box 6.1 + Ubuntu18.04 on windows 10,
Quartus pro 20.1 linux version + SOC EDS pro 20.1 linux version + Arm development studio 2022.0 linux version.
hardware platform: Intel Arria 10 SOC development Kit with a 3 year arm tools license.
The arm ds was activated with the license.
and today, i followed the steps on SoCEDS and ARM Development Studio | Documentation | RocketBoards.org, to exercise the sample application.
after i imported the Altera-SoCFPGA-HardwareLib-Timer-A10-GNU.tar.gz into my workspace and completed the debugger setting as below:
after i click on Debug to start a debugging session, The debugger didn't download the sample application executable on the board, and didn't run it up to the main function.
then i checked the commands window and found below errors
I searched these error on internet but found nothing usful for me. please give me your comments for this, thank you in advance.
0 项奖励
1 解答
Rainwang
新分销商 II
3,181 次查看
i found the root cause, the error is caused by the too early exit of uboot spl debugger bufore excecuting the app.
now i understand the app depends on the hardware initialization by the uboot spl.
so after successful running uboot spl, i disconnected the target and run the app examples immediately and it also succeed.
thanks.
在原帖中查看解决方案
0 项奖励
11 回复数
AR_A_Intel
员工
3,460 次查看
Hello
Welcome to INTEL forum. To narrow down this issue, can you please provide me the latest of the following?
1) Debug.log file
2) license.dat file
You can also reply/attach your file in private message.
0 项奖励
Rainwang
新分销商 II
3,452 次查看
Considering the private license information, I had sent you these files via mail. I am not sure if you can get them.
For the debug.log you mentioned, I have not found it in arm directories, so I just copy the information which appeared on the console/commands/target console windows of the arm DS into a file for your reference.
If you told me where to find the debug.log, I will copy it to you then.
thank you!
0 项奖励
Rainwang
新分销商 II
3,450 次查看
the mail can't be sent out, so i attached the debug file mentioned above for your information. will you pls provide me a private path that i can share my lisense file to you? It seems i can't send you private message here.
thank you.
0 项奖励
AR_A_Intel
员工
3,437 次查看
We PM you a private message. Hope you received it.
0 项奖励
AR_A_Intel
员工
3,341 次查看
Continue support in private message mail. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
0 项奖励
Rainwang
新分销商 II
3,212 次查看
who can provide me a update for this issue? thanks!
0 项奖励
Rainwang
新分销商 II
3,182 次查看
thanks.
0 项奖励
Itzthiru
初学者
2,716 次查看
Hello Rainwang,
               Hope this query finds you well. I am facing the same issue while trying to use Arria 10 SoC for baremetal programming. I am using SOCEDS and ARM DS5. I am trying to execute the sample program that already given with SOCEDS package itself. But i am also getting the same error and can you please let me know how you resolved this issue. Thanks in advance.
0 项奖励
Rainwang
新分销商 II
2,674 次查看
pls see my solution, you need to run the uboot spl firstly then switch to app, because the app depens on spl to initialize the environment.
0 项奖励
Itzthiru
初学者
2,664 次查看
Can you please let me know in which machine you've tried whether in windows or Linux machine and help me with the below issues also?
When I try to execute bare-metal sample programs for the Arria 10 SoC on Windows using Arm-DS IDE, I encounter the following error message:
Target Message: Memory access caused precise abort. Debug Precise Abort Registers : DFSR = 0x00000817, DFAR = 0xFFFF2000 ERROR(TAD11-NAL18): ! Failed to write 4 bytes to address S:0xFFFF2000 ! Bus error on memory operation
After that from my understanding, I am getting that error because of booloader and I attempted to build the bootloader for Arria 10 SoC in a Linux environment using VirtualBox on my Windows machine. However, during the build process, I am getting the following error:
make socfpga_arria10_defconfig.
makefile:40: *** missing separator. Stop.
0 项奖励
Itzthiru
初学者
2,431 次查看
I have completed the installation and now i am working on the DMA of HPS component. Can you share any example files for toggling HPS LEDS in Arria 10 using direct memory access or i need to configure something before?
0 项奖励
回复
