573 Discussions
how to access f2h sdram through hps
CJere3
在使用hps调用tse ip核中,根据https://rocketboards.org/foswiki/Projects/AlteraSoCTripleSpeedEthernetDesignExample的tse示例工程。通过两个scatter-Gather DMA(master)与HPS中的f2h sdram(slave)进行tse的数据通信。
问题是:我如何通过上位机直接访问这个f2h sdram的内部数据,f2h sdram的寻址空间为0x00000000~0xffffffff,master为DMA,我不是很清楚是否能通过hps直接访问到sdram内部的数据(寻址空间是重复的),从而通过tse发送数据。
tse.png上位机并不是linux操作系统的,无法验证demo中的上位机程序,硬件工程师只能通过hps直接控制地址​的方式来进行操作
FawazJ_Altera
Hello, My apologize are you asking about how to access the SDRAM through fsh bridge? thanks
CJere3
Hello:
as shown in the graphic,f2h SDRAM connects to the scatter-Gather DMA,scatter-Gather DMA is mater and SDRAM is slave ,how i can access SDRAM through hps directly .what is the direction between DMA and HPS,can I access through hps directly,or how i can access DMA? SDRAM address is 0x00000000~0xffffffff
FawazJ_Altera
F2H SDRAM bridge is used to access DDR memory of HPS side by FPGA master (processor, DMA, or JTAG Master). You can read/write without any issues. the only thing that need to be considered is, the bridges should be enabled. To make this safely, let HPS configures the FPGA, and boots linux; on this case, you will guarantee the bridge enablement.
If you want to access DDR from HPS side, this can be done easily by using memtool in linux, you can read and write the DDR.
For DMA, you have to initialize the DMA to do the job for you. usually we use Nios II to configure the DMA, and then the DMA will transfer the data from FPGA side, to SDRAM HPS side. I am attaching an example of how to do that.
FawazJ_Altera
posted a file.
CJere3
 thanks for your reply,but i still don't clearly about the relationship between the DDR3 and the f2h SDRAM address.if i add 6 f2h SDRAMs.how can i Map the address relationships between them and the DDR3. every SDRAM address is 0x00000000~0xffffffff,what is the DDR3 address? for example ,i use DMA,should i control the DMA descriptor to access the DDR directly,and then access DDR through hps directly.I'm sorry it's my first time use tse and scatter-Gather DMA ip core.i referred the design downloaded in
https://rocketboards.org/foswiki/Projects/AlteraSoCTripleSpeedEthernetDesignExample?rpm_id=8083970&erpm_id=8083970&erpm_id=8083970&erpm_id=8083970&erpm_id=8083970&erpm_id=8083970&erpm_id=8083970&erpm_id=8083970&erpm_id=8083970&_ga=2.113202945.401678115.1550048297-1001826037.1545013780&erpm_id=8083970l
FawazJ_Altera
This is done through the SDRAM controller subsystem. each controller is connected to a DDR. Only one f2sdram bridge is sufficient.
As shown in the design I sent to you earlier. you can connect Avalon master on FPGA to Address Span extender IP. Inside this IP, you can define the starting region of your SDRAM which assigned to FPGA. This is configurable option.
in the example above, the address span extender looks at this sdram with base address of 0x20000000, so anything below this address is not seen by FPGA.
FawazJ_Altera
Hello, I would like to know if the description above could help. Thanks
CJere3
It has done.still have some problems.I will go on investigation.
FawazJ_Altera
Hello, Kindly let me know if you need any help. Thanks
