Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Can I use cmake to compile a SGX Application?
dai_c_
Hello,When I use SGX SDK,It use makefile to compile a SGX application, and Is it possible to use cmake to complie a SGX application?Thank you very much!
you_w_
New Contributor III
Hi dai
Of course, You can use any auto build system. If you want to use cmake, you need to add SGX related operations, to cmakelist file. For example, the operation to generate trust and untrust bridge code and operation to sign the enclave ...If you are familiar with cmake you can try that.  I'am not familiar with cmake, But it should be something like this.
#APP cmakelist
cmake_minimum_required(VERSION 3.5)
add_custom_command(OUTPUT Enclave_u.h Enclave_u.c
    COMMAND  $ENV{SGX_SDK}/bin/x64/sgx_edger8r --untrusted ../Enclave/Enclave.edl --search-path . --search-path /opt/sgxsdk/include
    COMMENT  "make ucode"
add_custom_target(
    ucode ALL
    DEPENDS Enclave_u.h Enclave_u.c
aux_source_directory(. srcs)
add_executable(app ${srcs})
#Enclave cmakelist
message(STATUS "dealing with .edl")
include_directories(. $ENV{SGX_SDK}/include ../Include $ENV{SGX_SDK}/include/tlibc $ENV{SGX_SDK}/include/libcxx)
#execute_process(COMMAND  $ENV{SGX_SDK}/bin/x64/sgx_edger8r --trusted ./Enclave.edl --search-path . --search-path /opt/sgxsdk/include)
add_custom_command(OUTPUT Enclave_t.h Enclave_t.c
    COMMENT  "make tcode"
add_custom_target(
    tcode ALL
    DEPENDS Enclave_t.h Enclave_t.c
add_custom_target()
aux_source_directory(. enclave_srcs)
aux_source_directory(./Edger8rSyntax edger_src)
aux_source_directory(./TrustedLibrary tlib_src)
message(STATUS, "$ENV{SGX_SDK}/lib64")
SET(CMAKE_EXE_LINKER_FLAGS "-Wl,--no-undefined -nostdlib -nodefaultlibs -nostartfiles -L/opt/sgxsdk/lib64 -Wl,-Bstatic -Wl,-Bsymbolic -Wl,--no-undefined -Wl,-pie,-eenclave_entry -Wl,--export-dynamic -Wl,--defsym,__ImageBase=0 -Wl,--gc-sections -Wl,--version-script=Enclave.lds")
SET(CMAKE_C_FLAGS "-m64 -O2 -nostdinc -fvisibility=hidden -fpie -ffunction-sections -fdata-sections -fstack-protector-strong")
SET(CMAKE_CXX_FLAGS "${CMAKE_C_FLAGS} -std=c++11 -nostdinc++")
add_executable(enclave.so ${enclave_srcs} ${edger_src} ${tlib_src})
target_link_libraries(enclave.so -Wl,--whole-archive sgx_trts -Wl,--no-whole-archive -Wl,--start-group sgx_tstdc sgx_tcxx sgx_tcrypto sgx_tservice -Wl,--end-group)
you
you_w_
New Contributor III
Hi dai
#APP cmakelist
add_custom_target(
    ucode ALL
#Enclave cmakelist
add_custom_target(
    tcode ALL
add_custom_target()
you
dai_c_
OK,Thank you very much!
