Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Unable to pass C struct with typedef to ECALL
Guy_M_
I need to pass a structure with a typedef to an ECALL from within the enclave. The structure is defined in "Def.h" and include in the .edl file.
What am I doing wrong? without the typedef, it works fine.
Def.h
my error
Hoang_N_Intel
This is a common user error in defining EDL file. When you include a header file in EDL file, you are not supposed to add the "#" sign. Please update the code to have only
include "Def.h"
instead of
#include "Def.h"
