Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
1559 Discussions
How to Work With Nested Includes on .edl files
Guy_M_
Hi
Assuming I have an "enclave.edl" file and  two header files "definitions1.h" and "definitions2.h"
when I use "second_type" from "definitions2.h" in my "enclave.edl" it does not recognize it,
but when I use "first_type" from "definitions1.h" it works fine.
why does that happen, and how can I make it work?
(I can put all my definitions in the first header file but it creates a big mess.)
enclave.edl
enclave
#include "definitions1.h"
    trusted
          ecallFoo(second_type test);
    untrusted
definitions1.h
#ifndef TRUSTED_DEFINITIONS1_H_
#define TRUSTED_DEFINITIONS1_H_
#include "definitions2.h"
#define first_type int
#endif /* TRUSTED_DEFINITIONS1_H_ */
definitions2.h
#ifndef TRUSTED_DEFINITION2_H_
#define TRUSTED_DEFINITION2_H_
#define second_type int
#endif /* TRUSTED_DEFINITION2_H_ */
Hoang_N_Intel
The nested header file should work. There are a couple of issues of the code that you provided:
1. In the EDL trusted part, you should declare the function as public and have a return type such as
trusted
    public void ecallFoo(second_type test);
2. Please remember that the EDL gets compiled so any definition of "#define second_type int" is translated back into "int" in the generated code. If you want to use second_type again, you simply need to add the "include" statement in the c/cpp file again such as
#include "definitions1.h" or #include "definitions2.h"
Please give a try and see whether the changes help.
