Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1546 Discussions
Cannot upgrade to latest PSW on Windows 10 Pro Version 1709
ginzberg__yehonatan
I'm trying to upgrade to Intel SGX PSW for Windows v1.9.106.43403 (hoping it'll solve issue I'm having with VTune - but that is another matter) with no luck - at the beginning of the msi installation I'm getting the following message
Operating system "Windows 10 Pro 10.0.16299" is not supported.
Installation will end because this operating system is not supported.
Suggestion: Check Release Notes for a list of supported operating systems and install this product on a compliant system.
> I tried force cmd installation, logs show the same fatal error.
> The release notes mention my version of windows as supported
> The latest SGX SDK installed correctly
My current system:
1. SGX SDK v1.9.106.43403
2. SGX PSW v1.9.105.42329
3. Intel i7-7500U
4. Windows 10 Pro Version 1709 OS Build 16299.334
Are there any known issues with the installation? Is it possible that i'm running an advanced version of windows that is not supported? (Win10 10.0.16299.309 public release on March 13 >> latest PSW was released on March 16 >> I'm running Windows Build 16299.334 from March 22)
Francisco_C_Intel
>i.e. does it also place new PSW dlls that arrive with the PSW installation package?
Yes. The driver package for the Software Component device consists of DLLs, EXEs, etc. that make up the PSW. Instead of having an EXE or MSI install the files, we are using a declarative INF to do this.
>How can I verify?
You can go to the "Services" console and look for Intel(R) SGX AESM. If it's there, it was installed, and the Properties will also tell you the path for the executable, for example
C:\WINDOWS\System32\DriverStore\FileRepository\sgx_psw.inf_amd64_df0bea5643beeb1b\aesm_service.exe
You can then go to that directory inspect the binaries for their version number if you like.
Francisco_C_Intel
Please check
Device Manager -> Software Components
In Windows Version 1709, this is where the SGX PSW install is shown (instead of Add/Remove Programs), and gets installed automatically by Windows update.
If you have an environment that is not configured for Windows Update, you can use sgx_base.inf and sgx_psw.inf, included in the download from registrationcenter.
Francisco
ginzberg__yehonatan
Thank you Francisco, My environment is configured for Windows Update, I've checked the status manually and it reports to have the latest updates.
Manual update of the driver (via Device Manager) does seem to update to latest version - but I wonder whether this method capture the whole update? i.e. does it also place new PSW dlls that arrive with the PSW installation package? How can I verify?
Francisco_C_Intel
>How can I verify?
