Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1540 Discussions
Could someone help explain the function and the routine of the codes of intel/sgx-ra-sample in the Github?
Blade__Tom
Hi, I'm learning the samplecode of the remote attestation in the Github to study the main routine of developing an enclave by remote attestation, but it's too many files to read, so I can't figure out it.Could someone tell me  the function of each file,or the main routine of developing an enclave by remote attestation? Thank you!
By the way, my hareware can't support the SGX, how can I use the SGX and run the Remote Attestation samplecode?
The resource is : https://github.com/intel/sgx-ra-sample#build-linux
