Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Does SGX-SSL supports AES-NI inside enclave?
Scott_R_Intel
Hello Felix.
Your subject asks one thing, while the actual question asks another, so you may need to clarify if I don't answer the right question(s).
Firstly, yes, AES-NI is supported inside an enclave.
Not sure I understand the question inside, maybe a mis-type...  But, I think you mean does SGXSSL and/or the tcrypto libraries use AES-NI?  The answer is yes, both will utilize AES-NI if support is detected.
Regards.
Scott
Scott_R_Intel
Hello Felix.
Regards.
Scott
lin__felix
Thank you, sir. I try disassemble my code, and the result is exactly what you say.
