Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1550 Discussions
sgx_create_enclave returning 0x3002 SGX_ERROR_INVALID_ATTRIBUTE
Cipolla__Henry
On a fresh linux install, with the Driver, SDK, and PSW installed successfully, the LocalAttestation SampleCode fails because the call to sgx_create_enclave returns 0x3002. I added some tracing:
    printf("creating enclave 1\n");
    ret = sgx_create_enclave(ENCLAVE1_PATH, SGX_DEBUG_FLAG, &launch_token, &launch_token_updated, &e1_enclave_id, NULL);
    if (ret != SGX_SUCCESS) {
        printf("Failed. Return value is: %X\n", ret);
                return ret;
    printf("Return value: %X\n", ret);
Outputs:
creating enclave 1
Failed. Return value is: 3002
I don't see this error listed as a possible error in the docs https://software.intel.com/en-us/sgx-sdk-dev-reference-sgx-create-enclave so I'm turning to the community here for help.
Thank you for your time,
-- Henry
Cipolla__Henry
Turns out this is fixed by zeroing out the token.
Changing this line:
sgx_launch_token_t launch_token;
To this:
sgx_launch_token_t launch_token = {0};
makes it work. :)
Scott_R_Intel
Hi Henry.
Thanks for replying to your own post with the solution.  I noticed some of the other samples are also missing this initial zeroing too, so I will feed this back to the SGX dev team.
Regards.
Scott
