Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Eclipse Indexer do not working with sgx plugin
yulangz
I use SGX plugin on Eclipse. After importing the sample project, I can successfully build and run it. However, Eclipse shows 77 errors because Eclipse indexer cannot find header files such as 'CString'.
I also flow the guide from this issue https://github.com/intel/linux-sgx/issues/99, and the indexer can find the sgxsdk header files, but it still cannot find c/c++ built-in header files.
Sahira_Intel
In Eclipse, navigate to Project Properties -> C/C++ General -> Preprocessor Include Paths, Macros, etc.
Select the Providers tab and make sure "CDT GCC Built-in Compiler Settings" is checked. Hit Apply and Close and it should find the header files.
renditionDownload.jfif
Sincerely,
Sahira
Sahira_Intel
Sincerely,
Sahira
Sahira_Intel
Intel is no longer monitoring this thread. If you want a response from Intel in a follow-up question, please open a new thread.
