Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Segmentation fault (core dumped) and cannot call ecall
double
When I execute the following code, it reports an error: "[ERROR] Fail to Outcpu."
test.cpp
size_t X_row = 1024;
size_t X_col = 1024;
size_t Y_col = 1024;
size_t X_size = X_row * X_col * sizeof(double);
size_t Y_size = X_col * Y_col * sizeof(double);
double *X = (double *)malloc(X_size);
double *Y = (double *)malloc(Y_size);
ecall_status = ecall_Outcpu(eid, &ret,X, Y, X_row, X_col, Y_col, X_size, Y_size);
if (ecall_status != SGX_SUCCESS || is_error(ret))
    error_print("Fail to Outcpu.");
else
    info_print("Successfully Outcpu.");
free(X);
free(Y);
enclave.cpp
void ecall_mult_array(double *x, double *y, double *r,
					  int x_r, int x_c, int y_c, int size_x, int size_y, int size_r)
	for (int i = 0; i < x_r; i++)
		for (int y_j = 0; y_j < y_c; y_j++)
			double res = 0;
			for (int j = 0; j < x_c; j++)
				res = x[i * x_c + j] * y[j * y_c + y_j] + res;
			r[i * y_c + y_j] = res;
int ecall_Outcpu(double *X, double *Y, size_t X_row, size_t X_col, size_t Y_col, size_t X_size, size_t Y_size)
	size_t Z_size = X_col * Y_col * sizeof(double);
	double *Z = (double *)malloc(Z_size);
	ecall_mult_array(X, Y, Z, X_row, X_col, Y_col, X_size, Y_size, Z_size);
	free(Z);
	return RET_SUCCESS;
enclave.edl
enclave {
    // define ECALLs
    trusted {
        public void ecall_mult_array(
            [in, size=size_x]double *x,
            [in, size=size_y]double *y,
            [in, size=size_r]double *r,
        public int ecall_Outcpu(
            [in, size=X_size]double *X,
            [in, size=Y_size]double *Y,
    // define OCALLs
    untrusted {
I think the reason for the error is because the parameter passed is too large, so I change the 'test.cpp', 'enclave.cpp' and 'enclave.edl' to:
test.cpp
ecall_status = ecall_Outcpu(eid, &ret);
else
enclave.cpp
int ecall_Outcpu()
    free(X);
    free(Y);
	free(Z);
	return RET_SUCCESS;
enclave.edl
enclave {
    // define ECALLs
    trusted {
        public int ecall_Outcpu();
    // define OCALLs
    untrusted {
It reports an error:"Segmentation fault (core dumped)"
But when I change the 'X_row', 'X_col' and 'Y_col' to '205':
int ecall_Outcpu()
	size_t X_row = 205;
	size_t X_col = 205;
	size_t Y_col = 205;
    free(X);
    free(Y);
	free(Z);
	return RET_SUCCESS;
It works.
I want to know how to pass large parameters like 1024*1024 matrix to enclave. And how to calculate large matrix in enclave.
Thank you for your help!
Sahira_Intel
There is not enough memory allocated to the enclave to pass an array or declare an array of that size. You will need to adjust MaxHeapSize inside the enclave configuration file. I tested your code and I set MaxHeapSize to 0xF000000 to pass the array. Watch the number of threads in the TCSNum parameter in the enclave config file. The more threads you use the more memory you need to allocate.
You can also use the Enclave Memory Measurement Tool to measure the memory of your enclave so you can set Heap size accordingly.
Sincerely,
Sahira
Sahira_Intel
Thanks for the information. I am currently looking into this and will get back to you when I have a solution.
Sincerely,
Sahira R.
Sahira_Intel
Sincerely,
Sahira
double
Thank you for your reply.
I try it as your reply, but it doesn't work.
<EnclaveConfiguration>
    <ProdID>0</ProdID>
    <ISVSVN>0</ISVSVN>
    <StackMaxSize>0xf0000</StackMaxSize>
    <HeapMaxSize>0xf000000</HeapMaxSize>
    <TCSNum>10</TCSNum>
    <TCSPolicy>1</TCSPolicy>
    <!-- Recommend changing 'DisableDebug' to 1 to make the enclave undebuggable for enclave release -->
    <DisableDebug>0</DisableDebug>
    <MiscSelect>0</MiscSelect>
    <MiscMask>0xFFFFFFFF</MiscMask>
</EnclaveConfiguration>
tcs_num 10, tcs_max_num 10, tcs_min_pool 1
The required memory is 262217728B.
The required memory is 0xfa12000, 256072 KB.
Succeed.
SIGN =>  enclave.signed.so
The project has been built in debug hardware mode.
When I run the progarm:
a307@A307:~/md/hw_array$ ./sgx-array -C
[INFO] Enclave successfully initilised.
The initialize enclave time cost is: 1.242835 secs
The error display is the same as before, and I don't how to fix it.
Sincerely,
double
JesusG_Intel
Hello double,
The higher your TCS_Num, the more threads you use, and the more memory your enclave requires. Either increase the heap size or lower the number of threads, or both. If you must use multiple threads, you need to allocate more memory. We were able to use MaxHeapSize = 0xf000000 with a TCS_NUM = 1.
Sahira_Intel
Hi @double
Just following up to see if you were able to solve this issue.
Sincerely,
Sahira
