Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
1559 Discussions
Eclipse Indexer do not working with sgx plugin
yulangz
I use SGX plugin on Eclipse. After importing the sample project, I can successfully build and run it. However, Eclipse shows 77 errors because Eclipse indexer cannot find header files such as 'CString'.
I also flow the guide from this issue https://github.com/intel/linux-sgx/issues/99, and the indexer can find the sgxsdk header files, but it still cannot find c/c++ built-in header files.
Sahira_Intel
In Eclipse, navigate to Project Properties -> C/C++ General -> Preprocessor Include Paths, Macros, etc.
Select the Providers tab and make sure "CDT GCC Built-in Compiler Settings" is checked. Hit Apply and Close and it should find the header files.
renditionDownload.jfifrenditionDownload.jfif
Sincerely,
Sahira
Sahira_Intel
Sincerely,
Sahira
Sahira_Intel
Intel is no longer monitoring this thread. If you want a response from Intel in a follow-up question, please open a new thread.
