Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
Enclave.config.xml
littleQ
Hello! Recently, I used WAMR. I changed Enclave.config.xml,and got some error.
First, the original Enclave.config.xml is as follows:
<!-- Please refer to User's Guide for the explanation of each field -->
<EnclaveConfiguration>
  <ProdID>0</ProdID>
  <ISVSVN>0</ISVSVN>
  <StackMaxSize>0x100000</StackMaxSize>
  <HeapMaxSize>0x8000000</HeapMaxSize>
  <ReservedMemMaxSize>0x1000000</ReservedMemMaxSize>
  <ReservedMemExecutable>1</ReservedMemExecutable>
  <TCSNum>10</TCSNum>
  <TCSPolicy>1</TCSPolicy>
  <DisableDebug>0</DisableDebug>
  <MiscSelect>0</MiscSelect>
  <MiscMask>0xFFFFFFFF</MiscMask>
</EnclaveConfiguration>
I tried these behavious:
  1. I didn't modify the Enclave.config.xml, and used command make SGX_PRERELEASE=1 SGX_DEBUG=0 SGX_MODE=HW. The result is no error.
  2. I only modified MiscSelect option to 1, and used command make SGX_PRERELEASE=1 SGX_DEBUG=0 SGX_MODE=HW. The result is as follows:
Failed to create enclave from enclave.signed.so, error code: 1
Fail to initialize enclave.
The sgxsdk I used is the version of 2.19. I run the Cxx11SGXDemo in the linux-sgx. I only modified MiscSelect option to 1, and used command make SGX_PRERELEASE=1 SGX_DEBUG=0 SGX_MODE=HW. The result is no error.
Does it mean that WAMR doesn't support SGX2?
Wan_Intel
Hello LittleQ,
May I know what Operating System and Kernel version are you using on your machine?
You may check with uname -r command and lsb_release -a command.
Wan
littleQ
My kernel version is: 6.1.31-060131-generic.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.2 LTS
Release: 22.04
Codename: jammy
Wan_Intel
Hello LittleQ,
Thanks for your information.
Let me check with relevant team and I'll update you at the earliest.
Wan
Wan_Intel
Hello LittleQ,
Thanks for your patience.
We've received feedback from the relevant team.
Could you please try the following steps and see if the issue can be resolved?
  • Run the following command in your terminal
cpuid | grep SGX2
  • Build the kernel that allows EDMM with the following GitHub page:
https://github.com/intel/sgx-emm
Wan
Wan_Intel
Hello LittleQ,
Thanks for your question.
If you need additional information from Intel, please submit a new question as this thread will no longer be monitored.
Wan
