Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Enclave signing fails with undefined symbols when using icc
Spyridon_M_Intel
Hi, I had compiled, linked, signed and used my enclave with gcc and everything was working fine. I switched to icc and since then, I cannot sign my enclave. Specifically, the enclave passes the compilation and linkage stages, but I get the following error when signing:
[check_symbol_table elfparser.cpp:230] symbol '__intel_avx_rep_memcpy' is undefined
The input enclave file is not correct.
Error happened while signing the enclave.
I would like to note that I have linked my enclave with the -lirng and -lirc flags on. My OS is 14.04.1-Ubuntu 64bit.
Could you please help me out with that?
Thank you in advance!
Juan_d_Intel
What version of ICC are you using? Do you get the same error building one of the sample enclaves?
