Hello, I have the same problem with the issue here : https://community.intel.com/t5/Intel-Software-Guard-Extensions/CPU-has-latest-microcode-but-Attestat...
and get the solution as follows:
Follow these steps to mitigate SGX issues:
I know there is five microcode-update points from microcode-update-guidance .So I think the words Install the early load microcode means just FIT Microcode Update or Early BIOS Microcode Update ,is this right ? I have in touch with OEM, since the experts from OEM says they don't know the solution what could i do then?
Hello muye,
You are correct. Either FIT or Early Microcode Update is what you need. The latest BIOS update from an OEM may not contain all of the latest mitigations for a particular TCB. Hence the advice to: "Refer to your OEM to get the latest BIOS and inquire if it has the latest microcode with the required fixes implemented."
Sincerely,
Jesus G.
Intel Customer Support
Hello muye,
Sincerely,
Jesus G.
This thread has been marked as answered and Intel will no longer monitor this thread. If you want a response from Intel in a follow-up question, please open a new thread.
