Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Is it possible to derive the sealing key with sgx_get_key()?
sarodh_u_
Can the sgx_get_key() be used to derive the same MRSIGNER sealing key used in sgx_seal_data()?
Juan_d_Intel
Of course, sgx_seal_data() calls sgx_get_key() passing the appropriate key request.
See https://github.com/01org/linux-sgx/blob/master/sdk/tseal/tSeal_internal.cpp, line 67.
