Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Question on SGX UnSealing after TCB recovery
Anandakumar
新分销商 II
2,344 次查看
Hello All,
Does TCB recovery is needed for unsealing the data after BIOS update?
"I am not sure that I formed above question correctly."
Is it required to retrive previous TCB's seal key to unseal the data after TCB recovery/BIOS update?
I couldn't get detailed informations on how to get previous TCB version seal key. So I want more references/documents on TCB recovery.
Any updates or info will be appreciated.
Anand
0 项奖励
1 解答
JesusG_Intel
主持人
2,331 次查看
Hello Anandakumar,
You do not need to worry about the TCB update if you use the sgx_seal_data, sgx_seal_data_ex, and sgx_unseal_data API to seal and unseal data. According to the Intel SGX Developer Reference Guide for Windows or Linux:
"The sealing data API generates a data blob (sgx_sealed_data_t), which contains all the necessary information to unseal the blob even after updating the platform firmware. Without this information, unsealing may fail."
Sincerely,
Jesus G.
Intel Customer Support
在原帖中查看解决方案
0 项奖励
8 回复数
JesusG_Intel
主持人
2,332 次查看
Hello Anandakumar,
Sincerely,
Jesus G.
0 项奖励
JesusG_Intel
主持人
2,331 次查看
Hello Anandakumar,
Sincerely,
Jesus G.
0 项奖励
JesusG_Intel
主持人
2,332 次查看
Hello Anandakumar,
Sincerely,
Jesus G.
0 项奖励
Anandakumar
新分销商 II
2,313 次查看
Hi Jesus,
Thanks for your response. Now I undertood about the Sealing.
Regarding TCB Recovery/TCB update, What about the Remote attestation process after TCB update?
Do we need to anything specific to recover attestation key?
0 项奖励
JesusG_Intel
主持人
2,299 次查看
Hello Anand,
Attestation - SGX 101, https://sgx101.gitbook.io/sgx101/sgx-bootstrap/attestation#platform-provisioning, is a worthwhile read that will answer all of your questions. Excerpt:
"So how does QE obtain this attestation key in the first place? In this tutorial we explain the provisioning process in which an SGX platform receives its remote attestation key.
Provisioning is the process by which an SGX device demonstrates to Intel its authenticity as well as its CPU SVN and other system components attributes, in order to receive an appropriate attestation key reflecting its SGX genuinely and TCB version. Normally, provisioning is done during platform initial setup phase, but re-provisioning can also be performed after purchase due to update to crucial system components such as firmware, BIOS or microcode due to vulnerabilities. In such cases, the attestation key may be replaced to reflect platform renewed TCB security level."
Sincerely,
Jesus G.
0 项奖励
Anandakumar
新分销商 II
2,287 次查看
Hi Jesus,
I just want to know whether the Report attestation key retrival process happens automatically or any human input needed.
Anand
0 项奖励
JesusG_Intel
主持人
2,275 次查看
Hello Anand,
The generation of the new attestation key is done automatically by the AESMD. The user does not have to do anything specific.
Sincerely,
Jesus G.
0 项奖励
JesusG_Intel
主持人
2,252 次查看
This thread has been marked as answered and Intel will no longer monitor this thread. If you want a response from Intel in a follow-up question, please open a new thread.
0 项奖励
回复
