Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1545 Discussions
Quote Verification fails with an error 0xe01b (SGX_QL_NO_QUOTE_COLLATERAL_DATA)
user171960
Hello! I am having an issue with the quote verification process (it should be successful for the untrusted part). For some reason, the platform could not be registered. Could you help solving it? Thanks.
Info: ECDSA quote path: ../QuoteGenerationSample/quote.dat
Trusted quote verification:
Info: get target info successfully returned.
Info: sgx_qv_set_enclave_load_policy successfully returned.
Info: sgx_qv_get_quote_supplemental_data_size successfully returned.
Error: App: sgx_qv_verify_quote failed: 0xe01b
Error: Ecall: Verify QvE report and identity failed. 0xe013
Error: App: Verification completed with Terminal result: a006
Untrusted quote verification:
JesusG_Intel
Closing this thread as it is being handled privately.
JesusG_Intel
