Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1540 Discussions
SGX sign my enclave over GNU+Linux: Key file format is not correct.
Desyllas__Dimitrios
I read all the required manuals to understand the Intel SGX so I decided to make my own enclave for edicational purpoce therefore I did:
https://github.com/pc-magas/myFirstEnclave
I manage to build my enclave and now I try to figure out how to sign it so I generate with either:
  • Using the command:
    openssl genrsa -out $(KEY_FILE) 2048
  • Or using the ssh_keygen command
But in either case when I try to sign them with:
sgx_sign -key ^private_key_generated_above^ -enclave enclave.o -out enclave.so -config Enclave.config.xml
I get the response:
So I try to figure out how to sign my build enclave. Can you help me?
Ps I've also asked in https://stackoverflow.com/questions/47498426/sgx-sign-enclave-cannot-sign-the-build-enclave-key-file-format-is-not-correct
Hoang_N_Intel
Commands on how to create a key and sign with SGX are documented in the SGX Developer Reference at https://download.01.org/intel-sgx/linux-1.9/docs/Intel_SGX_SDK_Developer_Reference_Linux_1.9_Open_Source.pdf
Please refer to the section under "OpenSSL* Examples" for command to create a key and section under "Enclave Signer Usage Examples" for commands to sign with SGX.
Hoang_N_Intel
