Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
The following error occurs when installing Open Enclave:
shouheng
Iffa_Intel
Could you share:
  1. Your Kernel version. (Note: Linux kernel versions v5.11 and newer have the SGX driver that supports DCAP built in, so you do not have to (and should not try to) manually install the DCAP driver)
  2. Your output of ls -la /dev/sgx
Cordially,
Iffa
shouheng
Hello, my computer SGX boot mode is software boot, ubuntu version is 20.04, kernel version is 5.15, input command is shown as follows. In addition, I did not successfully enable the SGX function on the Linux system, I installed the SGX according to the documentation, but when the ubuntu system starts, it shows that the SGX has been locked, and only SGX virtualization is supported, could this be the reason?
Iffa_Intel
Could you
  1. help to check whether your CPU supports Intel SGX by running: cpuid | grep sgx
  2. confirm that the required SGX kernel modules are loaded by running: lsmod | grep isgx
Cordially,
Iffa
Iffa_Intel
Thank you for your question. If you need any additional information from Intel, please submit a new question as Intel is no longer monitoring this thread.
Cordially,
Iffa
