Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Unable to use the registered development certificate for remote attestation of Intel SGX
yeongjin_j_
To test/use the remote attestation functionality, I have registered myself to Intel Trusted Services Infrastructure and sent a self-signed certificate.
After getting the response, I tried to use various methods to connect to the URL:
https://test-as.sgx.trustedservices.intel.com:443/
I tried:
1. TLSv1.2 connection using OpenSSL
2. Use web browser by setting the client certificate as the requested one
3. Clone this (https://github.com/svartkanin/linux-sgx-remoteattestation) repository and set my certificate in that code.
However, from all of the methods that I listed, what I keep getting is that TLS connection cannot be established.
I have checked PCAP during the communication and I can see that client requests TLSv1.2,after client certificate / client key exchange / client certificate verification, the IAS server just send FIN (disconnect).
My clue is that my self-signed certificate is not registered correctly
(although from access.log on my server I can see that the Intel IAS have grabbed my certificate),
but registration service representative recommended me to post a question at this forum.
Is there anyone who suffered the same problem?
Roshan_Mehta
Did you make it work? I am facing the same problem.
Hoang_N_Intel
First, you need to make sure that you are using the correct cert and key by running these two commands:
$ openssl x509 -noout -modulus -in client.crt
$ openssl rsa  -noout -modulus -in client.key
They should display the same modulus info.
Then you need to display the cert to make sure that it is the cert that you have submitted to Intel:
$ openssl x509 -in client.crt -text
Finally, test the connect with the cert to see whether you can complete the SSL handshake or not:
$ openssl s_client -connect test-as.sgx.trustedservices.intel.com:443 -cert client.crt -key client.key
Please note that test-as.sgx.trustedservices.intel.com is for the DEV environment. Production has a different endpoint.
Mon__Eddie
I have the same issue and would like to know how to address it.
