Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Use SGX to pack non-SGX lib
KT_L_
Hi..
I have a SGX question
If I got a algorithm lib/dll whcih is non-SGX coding and I don't have the source code.
I plan to write a SGX  function and call this non-SGX  API lib.
Is non-SGX lib protected by SGX?
Surenthar_S_Intel
Hi KT,
No, it will not provide any SGX security for non SGX lib. Because the non SGX lib stored on untrusted memory.
Thanks and Reagrds,
Surenthar Selvaraj
Surenthar_S_Intel
Hi KT,
Thanks and Reagrds,
Surenthar Selvaraj
KT_L_
Hi Surenthar
Thanks for your reply.
So there are no way to make non-sgx lib be proercted by SGX without re-writing the lib with SGX?
If answer is no, I will ask the vendor whcich provide our algorithm to re-write it under SGX environment.
Someone tell me that ARM; trustzone can do it. That's why we think it maybe ok to wrap the non-sgx lib in SGX code.
Thanks  KT
Muthumanic_V_Intel
Hello KT,
The untrusted library functions can only be called from application code - outside the enclave. The trusted libraries are static libraries that link with the enclave binary. The Intel® Software Guard Extensions Evaluation SDK ships with several trusted libraries that cover domains such as standard C/C++ libraries, synchronization, encryption and more. These functions/objects can only be used from within the enclave.
Note: Do not link the enclave with any untrusted library including C/C++ standard libraries. This action will either fail the enclave signing process or cause a runtime failure due to the use of restricted instructions.
In your case please do rewrite the algorithm with in the SXG environment.
Muthu
KT_L_
Hi Muthu,
Thansk for your detail explain. really appreciate.
