Intel Confidential Computing
Discussion board focused on Intel Confidential Computing technologies and how they can protect data and AI security, privacy, and sovereignty.
Question about MTLS between SP and IAS?
shen_y_
Hi
I've registered my SP with IAS and received a SPID and a Report Key link.
My question is :
1. Is the Report Key needed in MTLS or remote attestation? If true, how to use it ?
2. MTLS means that both SP and IAS must present a valid (not expired or revoked) X.509 certificate for authentication.I've provided SP's certificate to IAS and received a SPID,how to get IAS's certificate?  In my opinion, I should put the IAS's certificate in SP's truststore used for TLS1.2 authentication when I access IAS WebService which is supplied for remote attestation. Is my understanding right?
Thanks and Regards,
Yu
Surenthar_S_Intel
Hi Yu,
We have a code sample for remote attestation that is nearing release. It should be ready soon. This sample has will likely address your question.
Thanks and Regards,
Surenthar Selvaraj
shivani_g_
Hi Surenthar
Will a code sample for remote attestation for linux OS will also be released soon ?
I was trying to communicate with SP directly via sockets. I'm able to successfully complete the TLS handshake. But after writing the request to socket my SSL_read() always fails and I'm unsure why.
Thank You
Surenthar_S_Intel
Hi Shivani,
At this time there are no plans to provide a remote attestation sample for Linux OS.
