Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
i can't find Enclave project in visual stdio 2017
newsgxer
Einsteiger
15.415Aufrufe
when i have installed the required softwares like INTEL ME,SDK,PSW as i thought,i can't find Enclave project in visual stdio 2017.VS 2017 was installed earlier than  SDK was.I have tried several times to build sgx following the given instructions and googled for solutions ,but it didn't work out.
Would you please give me some suggestions? Thanks a lot
Beschriftungen (2)
1 Lösung
JesusG_Intel
15.139Aufrufe
Hello newsgxer,
I have an update. The fixed SGX SDK for Windows that integrates with Visual Studio will be released at the end of January.
Sincerely,
Jesus G.
Intel Customer Support
Lösung in ursprünglichem Beitrag anzeigen
20 Antworten
JesusG_Intel
15.366Aufrufe
Hello newsgxer,
You should be able to find the Enclave Project in the Visual C++ section.
  1. Open Visual Studio 2017
  2. Click File | New | Project | Visual C++ | Intel® SGX Enclave Project
You can also search for Enclave in the New Project Search box.
If Intel SGX Enclave Project is not available in Visual Studio 2017, try installing Visual Studio 2019.
See the attached file for a screenshot of where Intel SGX Enclave Project appears in the New Project dialog box.
Sincerely,
Jesus G.
JesusG_Intel
15.354Aufrufe
Hello newsgxer,
Were you able to find the new SGX project in Visual Studio?
Sincerely,
Jesus G.
newsgxer
Einsteiger
15.346Aufrufe
Not yet.i have installed vs2017 ,vs2017pro,vs2019,and the sgx preject can't be found .
JesusG_Intel
15.333Aufrufe
Hello newsgxer,
  1. Provide a screenshot of the New Project dialog box with the Visual C++ section expanded.
  2. Import enclave into a new, blank solution:
    1. Click File | New | Project | Visual C++ | Console App
    2. In Solution Explorer, right-click on the Console Application project
    3. At the bottom of the dialog box, select Intel SGX Configuration | Import Enclave
If you do not see the Intel SGX Configuration option in the project properties then the SGX SDK did not properly integrate with Visual Studio.
Ensure you have installed the Microsoft Visual C++ Compiler with Visual Studio.
Try opening one of the sample solutions included with the SGX SDK, such as SampleEnclave, and check if it compiles.
You can also try re-installing the SGX SDK.
Sincerely,
Jesus G.
newsgxer
Einsteiger
15.318Aufrufe
Thanks a lot for your advice.
I won't give up.
JesusG_Intel
15.304Aufrufe
Hello newsgxer,
Have you tried installing on another PC? Just to check if you can get the integration to work, you don't need SGX, all you need is Visual Studio and the SGX SDK.
Sincerely,
Jesus G.
newsgxer
Einsteiger
15.293Aufrufe
Hello Jesus G,
Yes,i have tried to install sgx on another PC and my roommate's PC.The results are that the sgx project is unable to be found. Also,i  tried to run the SampleEnclave without sgx projects found in VS,which brought many mistakes that mainly are the as the followings:
1. the original problem: no sgx projects found in VS(2017pro or 2019)
2.VS can't Identify the edl file like Enclave.edl
3. how to sign the dll file like Enclave.dll
4.how to integrate my sgx project into other projects .When i right-click the project ,no intel sgx configuration was found.
Looking forward to your reply.It is important to me.
Yours,
newsgxer.
JesusG_Intel
15.287Aufrufe
Hello newsgxer,
Let's try some troubleshooting steps:
  1. What is your OS version and build number?
  2. Uninstall Intel Software Guard Extensions SDK for Windows from Programs and Features
  3. Double-click on Intel(R)_SGX_Windows_SDK_2.11.100.3.exe to install the Intel SGX SDK for Windows v. 2.11 (is this the version you are trying to install?)
  4. Confirm the first screen, after the initial splash screen, on the installation GUI shows the check boxes for Intel® SGX Visual Studio Integration and Intel® SGX Visual Studio Debugger (see the attached screenshot)
  5. After installation is complete, you will find installation logs in the %temp% directory. The logs have a prefix of "dd" and are named similarly to dd_setup_20201208084321.log. You should see logs with VisualStudio in the file name. Compress these logs and send them as an attachment to this thread.(see the attached screenshot)
Sincerely,
Jesus G.
newsgxer
Einsteiger
15.276Aufrufe
Hello Jesus G
My OS version and build number are Windows10 Education 1809 version and 17763.1577
Intel(R)_SGX_Windows_SDK_2.11.100.3,it is the version i have installed.
It seems that something indeed went wrong with the installation.
I'll read logs and try to figure it out.Also look forward to your advice.
yours,
Newsgxer
newsgxer
Einsteiger
15.271Aufrufe
the rest of the photos
JesusG_Intel
15.250Aufrufe
Hello newsgxer,
I was able to reproduce your issue - not able to integrate the SGX SDK with VS2019. I submitted that issue to engineering for further investigation.
Here are some other steps you can try:
  1. Remove all versions of Visual Studio except Visual Studio 2017 Professional edition.
  2. Delete the directory: C:\ProgramData\Intel\Installer\SGX_SDK
  3. Reinstall the SGX SDK
  4. Send a log named dd_VSIXInstaller...
Sincerely,
Jesus G.
newsgxer
Einsteiger
15.236Aufrufe
Hello Jesus G
See this log which reported that it's the OS's compatible issues.It sems that the SDK downloaded from the website did't work well  windows10 version 1809 and builder number 17763.1577.Right now i manage to install SDK on OS whose version is before 1709 or the latest OS version and 32bit(the log shows that the SDK requires 32bit OS).I think it's better to creat Enclave project in VS.Also i'll try to use SampleEnclave as a base for my project.
Sincerely,
Newsgxer.
JesusG_Intel
15.244Aufrufe
Hi Newsgxer,
Even without the integrations, you should be able to load and compile the SampleEnclave. You can use that as a base for your projects.
JesusG_Intel
15.234Aufrufe
Hi newsgxer,
When you say that you managed to install the SDK does this mean that you were able to integrate it with Visual Studio?
Can you find the new SGX Enclave Project?
Sincerely,
Jesus G.
newsgxer
Einsteiger
15.218Aufrufe
Hello Jesus G,
Unfortunately i failed again.I installed SGX SDK on Windows Education 20H2,build number 19042.631,which is the latest version.Next i'll try to install SDK on earlier version like 1607.Wish me luck.
Look forward to your reply.
Yours,
Newsgxer
newsgxer
Einsteiger
15.211Aufrufe
hi Jesus G
I read the logs again.Surely it's the version of the Windows and components of VS that can't integrate with the SGX sdk.So would you please give some advice on which version or some contraints of the version that the SGX sdk needs.One of my senior told me that he succeed for only one time.Hence,i need to change the configurations of my PC.Maybe there are some other problems that i didn't mention.If possible,please write to me so that i'll get it correct.
Yours,
Newsgxer
JesusG_Intel
15.132Aufrufe
Hello newsgxer,
I apologize for my delay in response as I was on vacation.
Unfortunately, I don't have any updates. We have been able to reproduce this issue and engineering is looking into it. I will continue to work with them to get a response.
I will post on this thread as soon as I have an update.
Sincerely,
Jesus G.
JesusG_Intel
15.140Aufrufe
Hello newsgxer,
Sincerely,
Jesus G.
newsgxer
Einsteiger
15.119Aufrufe
Hello Jesus G,
I'm so excited to hear it.
Thanks a lot.
Yours,
Newsgxer
JesusG_Intel
14.985Aufrufe
This thread has been marked as answered and Intel will no longer monitor this thread. If you want a response from Intel in a follow-up question, please open a new thread.
Antworten
