Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
sgx_ecc256_compute_shared_dhkey Symmetric Encryption
glaser__manuel
I develop a Client -Server program and used the function sgx_ecc256_copute_shared_dhkey. After that I
want to use the shared key to encrypt data symmetric with the exchanged key. Unfortunately I do not find
any encryption method with a 256 symmetric key. Is there a possibility to encrypt it with the exchanged key?
Or what is the reason for this function within the SGX SDK ?
Omarama
glaser__manuel
I calculated the symmetric password using the sgx_sha256 to generate a secret password. It' working
