Hello there, I am having trouble connecting my iPhone to my PC via Bluetooth. It does not prompt me a Bluetooth code on either devices. However it does work on my other PC. Is there any solutions for this problem? Thanks!
链接已复制
Hello Miguel123,
I am sorry you are having issues with the Intel® Unison™ app, I will be glad to assist you.
Please confirm the following information:
- Were you able to connect both devices before?
- Make sure you have followed the two following steps correctly:
- Connect a laptop and a smartphone to the Internet and enable Bluetooth from both devices.
- Click Scan QR Code button on laptop
- Open Intel® Unison™ app on smartphone.
- Scan the QR code using the smartphone and select Allow when you get the permission request to use the phone’s camera.
- Once the permission is granted and opened from the smartphone, scan the QR Code on the laptop side.
Or To Use a Text Code instead:
- Enter the code into the text field shown on the laptop.
- If the code is not fully filled with 8 characters/digits, the button is disabled.
- To initiate the connection to the PC, click Connect.
Look forward to hearing back from you.
Steven G.
Many thanks for your response.
In order to investigate further, please provide the following information:
- Was the Intel® Unison™ app pre-installed or downloaded from the Microsoft Store?
- Provide the Intel® Unison™ app version, iPhone model + iOS version, and finally mobile Intel® Unison™ app version.
- In your PC, download the Intel® SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything", click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". To save your scan, click on "Next", then "Save". Please attach the file to your reply.
Steven G.
I downloaded it through Microsoft Store
Intel Unison PC version u:10.9.2833/c:10.8.2911.0, iPhone 11 iOS 16.3, Intel Unison Mobile Version 10.9.0 [1569]
I've attached a .txt file
Hello, @Miguel123.
Thank you for your time.
We noticed in your Intel® SSU report that your system doesn't meet the minimum requirements for the Intel® Unison™ app.
Your system has an Intel® Core™ i5-4670 processor and for this app, it is required to have a 13th gen processor or above (*Selected 12th Generation processors). Also, your OptiPlex 9020 desktop has no wireless card, only Ethernet connection, and this is connected via Bluetooth.
You can verify the minimum requirements you need to get this app running: What Are the System Requirements for the Intel® Unison™ App?
Jocelyn M.
Bluetooth di "IOS" e quello di un pc "Windows"
