Opération réussie ! Abonnement ajouté.
Opération réussie ! Abonnement supprimé.
Désolé, vous devez procéder à une vérification pour effectuer cette action. Veuillez cliquer sur le lien de vérification dans votre e-mail. Vous pouvez le renvoyer à partir de votre profil.
Hi, I am trying to set up the Intel Unison app on my PC and my iPhone. But it is a bit sketchy, because it seems that I can not connect my phone and my PC trough the app, but I can send files. The files are sent to my PC, I even see a loading bar inside the Unison app, but cant interact in any way or see the history, calls, messages or anything else. But the file is transfered in the right directory and is alright, but the app itself, doesnt work ?
The error pops up if it says something like: Trying to pair your phone and PC, please confirm the bluetooth connection (I am from germany, I translated it).
If I try to connect them again, it either just loads a bit and returns to the start connection screen or doesnt even load and does nothing. All while the phone is connected already through Bluetooth with the PC.
I also unpaired the phone and tried again. I reinstalled the app on my phone and the PC, updated the bluetooth drivers, tried many different things. I Tried to pair it with my iPad, but the app says its no phone so not possible, so I can't tell if its the phones fault.
info picture:
Lien copié
Hello, I can't pair my pc with my mobile I think so it doesn't show up in pc app gallery messages etc. but if I send a photo from my mobile to pc it gets saved to a folder in pc Intel Unison
Hello blatantq1,
May I ask what your wireless/Bluetooth adapter make and model is? You may also share your system configuration so I we can fully check and provide you with an accurate fix. This could be possible by downloading the Intel® System Support Utility for Windows* software. When the download is complete, launch SSU.exe.
Please also make sure that your IOS version is iOS* 15.x and above.
Reference: What Are the System Requirements for the Intel® Unison™ App?
I hope to hear from you soon so I can proceed with further checking on this issue.
JeanetteC.
my bluetooth is tp link UB500
Having this exact same issue.
Everything is up to date, iPhone PC, etc.
ello blatantq1,
The issue is still currently being checked. Please confirm the details below:
1. Can you pair another Bluetooth device with your desktop PC (e.g. BT keyboard and mouse, BT speakers, etc.)?
2. Is your iPhone also able to connect to other Bluetooth device (e.g. Bluetooth speakers/headphones, etc.)?
3. Are both devices (desktop PC and iPhone) connected to the same home/wireless network?
I hope to hear from you so I can proceed with further checking.
JeanetteC.
I exactly have the same issue, impossible to have access to the messages, photos, notifications...
What is strange is that I can share documents from my device to the laptop.
This is not working between the ipad and the laptop neither.
Thanks!
Hello PhiPhi,
I understand that you are facing exactly the same problem with the Intel® Unison™ app. However, I kindly request that you create a new thread for your case. This will allow us to focus on your specific problem and provide you with better assistance.
Sincerely,
JeanetteC.
Hello blatantq1,
Good day.
From the picture provided, the iPhone in File Transfer is grey and disable. It might be due to iPhone and PC app are not the same latest version 20.27.x, USB BT issue and iPhone permission. iPhone General Settings > Bluetooth name must same as connected in PC'OS/DM Bluetooth and Intel Unison PC App settings.
Photo, video, media, gallery, messages, contact list and notification access must be "Always allow all" instead of "preferred setting or asking to allow access" from iPhone General settings. Both PC and iPhone status in Intel Unison PC App must "connected" then have same PIN number to pair successfully. I suggest checking iPhone General settings to allow all permission. Sharing the User Guide for pairing (page 20) and iPhone message limitation (pages 46-47).
Additionally, on about iPad issue. When pairing with iPad, you need to select Tablet icon and not Phone
I hope this helps.
JeanetteC.
Hey mate,
I made an account just to post the solution I discovered deep in a reddit thread.
It worked for me when pairing my PC and phone wouldnt work through the app, regardless of if I was paired already or not.
"For anyone having troubles connecting: If you have the same issue I did where it was saying bluetooth connection wasn't paired but still showed your device and the battery percentage here's something that got it to work:
On your phone try sending your PC a picture, if it worked then that means you can try the bluetooth pairing AGAIN and it should work this time. This has worked for both me and a friend. If it maybe says "Connection failed" try forgetting the devices in the bluetooth settings on BOTH devices and restart."
Hope that helps anyone struggling!
L'assistance à la communauté est fournie du lundi au vendredi. D'autres moyens d'entrer en contact sont disponibles ici.
Intel ne vérifie pas l'intégralité des solutions, y compris, entre autres, les transferts de fichiers qui peuvent avoir lieu au sein de cette communauté. Intel décline donc toutes garanties explicites et implicites, y compris, sans s'y limiter, les garanties implicites de qualité marchande, d'adéquation à un usage particulier et de respect des droits de propriété intellectuelle, ainsi que toute garantie découlant des performances, des transactions ou de l'utilisation.
Pour obtenir des informations plus complètes sur l'optimisation des compilateurs, voir notre Avis d'optimisation.
