5169 Discussions
12-pin AXXTPMENC8 TPM for S2600ST LGA 3647 motherboard
Miyconst
Hello there. I am trying to find a TPM 2.0 module for my Intel S2600ST dual socket LGA 3647 motherboard.
According to the manual, it should be a 12-pin AXXTPMENC8 module, the only problem is that AXXTPMENC8 is a 14-pin module while the motherboard's connector is indeed a 12-pin one.
Where can I find this misterious 12-pin connector or at least some specification of it.
More info with pictures and screenshots is available here:
https://miyconst.github.io/hardware/2024/07/27/intel-s2600-tpm20.html
Keymaster2014
I have the same problem. Did you happen to find out which TPM works for this server board?
Just like you, I noticed the discrepancies between the TPM of 12 pins and 14 pins. I noticed that the older documentation refers to AXXTPMENC8 as a 12 PIN TPM (on the motherboard manual). But the newer documentation refers to AXXTPMENC8 as a 14 PIN TPM 2.0 (on the marketing documentation). My suspicion here is that they originally came as 12 PIN TPM version 1.2 but in later revisions were changed to 14 PIN TPM 2.0 (since they are more secure).
This is my assumption, but It would make sense.
So, the problem is where would you be able to find an older AXXTPMENC8 with 12 pins? Since the part is at EOL, all I would say is to find some luck on eBay from an older board.
If you happen to find some, let me know.
Miyconst
Hi there.
I have purchased several of these AXXTPMENC8 modules with a hope to get one 12-pin variant, and surely enough, one was with 12-pins, of course I cannot guarantee that you will also get a 12-pin, but I ordered from here:
https://www.amazon.de/-/en/dp/B07JVPJ9T8
Then the module was inspected by BIOS-iEngineer (you can Google who he is) and he made a copy. If you don't want to pay $80+ for that silly module - contact him, maybe he will agree to sell scematics and PCB Gerber file for a DIY project.
In this video of mine you can see the Engineering Sample TPM module he made for my Intel S2600STB motherboard:
https://www.youtube.com/watch?v=qhmHNuvEID0&t=306s
Miyconst
Hi Ragulan. Thank you for the extra info but how does it help me? This thread is half a month old and got more than 15 messages from almost 10 different Intel employees. So far, nobody can give me a clear answer, where is the documentation and specification of AXXTPMENC8, is it a 12-pin or a 14-pin module, and where it is or was available for purchase?
I know that AXXTPMENC8 was discontinued but that does not help me in any way. It is remarkable but the official specification page of AXXTPMENC8 does not specify how many pins this module has. Here is the product page:
 Trusted Platform Module 2.0 AXXTPMENC8 Product Specifications (intel.com)
Mouser Electronics is a large distributor that claims that AXXTPMENC8 is a 14-pin module.
Intel_Server_Board_S2600ST_TPS_1_0-1131359.pdf (mouser.com)
Here is another Intel guide that also claims that AXXTPMENC8 is a 14-pin module.
https://cdrdv2-public.intel.com/638427/Intel_Server_M50CYP_Family_Configuration_Guide_Rev1_11.pdf
Could you please just give me a simple PDF file with pinout specifications and pictures of the 12-pin AXXTPMENC8 module?
MACM
Hi Miyconst,
Greetings from Intel.
Hope you are doing great.
We regret to inform you that the AXXTPMENC8 module has reached its End of Life (EOL) status.
Consequently, we have shared all the available information regarding the TPM 2.0 with you.
Unfortunately, due to the discontinuation of this product, the specific pinout specifications and pictures you requested may no longer be available.
We apologize for any inconvenience this may cause and appreciate your understanding in this matter.
We will go ahead and archive this case if we do not get any response by the EOD.
Mohammed Ali CM
Miyconst
Hi, again Mohammed.
Do I understand you correctly, that because AXXTPMENC8 is EOL, Intel does not know how many pins it has (or had) and does not have any specifications?
To be honest, this sounds completely ridiculous. I am not asking for warranty service, I am not asking to sell me an EOL product, I am simply asking for the specification of an Intel product. If this is the wrong place to ask, who shall I turn to?
Sazirah
Hi Miyconst,
Upon checking, unfortunately the 14-pin TPM photo in S2600ST configuration guide is out of date and should be 12 pin. Our humble apologies for this confusion caused.
Attached photo is an AXXTPMENC8 physical module, which has PBA J33565-xxx and it's 12-pin and that as it is end of life it may be available through the sources below but Intel® cannot guarantee their inventory levels and does not support warranty or support these products.
Shall you require any other assistance regarding this, kindly let us know.
Sazzy_Intek
MACM
Hello Miyconst,
Thank you for contacting Intel.
This is the first follow-up regarding the issue you reported to us.
We wanted to inquire whether you had the opportunity to review the plan of action we provided.
Feel free to reply to this email, and we'll be more than happy to assist you further.
Mohammed Ali CM
Intel Customer Support
Miyconst
Hello MACM and Sazirah.
Unfortunately, your answers are absolutely useless and the so-called "plan of actions" does not help in any way.
I still don't know and you failed to asnwer:
- Where to buy a 12-pin module AXXTPMENC8.
- Why Intel authorized distributors have no idea about the 12-pin version of AXXTPMENC8.
- Why Intel authorized distributors sell 14-pin AXXTPMENC8 modules instead.
- Why Intel documentation in one place says that AXXTPMENC8 is 12-pin and in another place says that it's 14-pin.
- What is the pin-out specification of the 12-pin module.
Poojitha
Hi Miyconst,
We would like to inform you that product configuration guide is currently out of date, and there are no updates available for this document at present.
For purchasing the TPM module, you can refer to the configuration guide. Using the same part number will ensure that you receive the 12-pin module. To make a purchase, please contact our authorized Intel distributors or resellers.
In addition, we will consult with our internal team once again to explore the best possible solutions for obtaining the product you need. We sincerely apologize for any inconvenience caused.
Please find the Intel distributor link:
https://www.intel.com/content/www/us/en/partner/showcase/partner-directory/distributor.html#sort=relevancy
Thank you for your understanding!
Poojitha N
Miyconst
Hi Poojitha.
I am not sure why we are going around the same issues all over again. Thank you for the answer but it does not help in any way and only adds even more frustration to the issue.
Do I understand you correctly, that Intel silently changed a product from a 14-pin to a 12-pin connector, did not update the documentation, did not inform the authorized retailers about it, and does not even have documentation about the new 12-pin version?
It seems like you either didn't read my messages or just mocking me. I have already specified multiple times, that I have contacted several authorized retailers, they offer me 14-pin version, but they have no clue about the 12-pin option. Maybe you can send me a link to a product page instead?
I understand that AXXTPMENC8 is end of life, I understand that it may no longer be available for purchase, and I understand that the documentation is outdated and wrongly mentions the 14-pin version. All I am asking for is a simple PDF file with the pinout specification of the 12-pin version of the AXXTPMENC8 TPM 2.0 module.
Subhashish
Hi Miyconst,
Thank you for writing to us. As per your request for a PDF/Document wherein it specifies the TPM Module AXXTPMENC8 TPM 2.0 of 12 PIN's PIN Layout information/diagram and specification for the this module, we will check if there is a document available to public for same or if the document will be available in Intel RDC with special access and get back to you.
Kindly await our next communication.
Subhashish_Intel.
Ragulan_Intel
Hi Miyconst,
Greetings!
Please find the updates we have gotten from our internal team in regards with your queries.
  1. AXXTPMENC8 is 12-pin. and not 14-pin module, it might be a previous generation TPM for other generation server board, which is showed in https://www.intel.com/content/www/us/en/support/articles/000017015/server-products/server-boards.html. 12-pin is the TPM AXXTPMENC8 used for S2600ST
  2.  Our engineering team doesn't have any documentation with 12 Pin TPM Module.
  3. In customer's page, there is a link https://www.ebay.com/itm/266562844499?mkcid=1&mkrid=711-53200-19255-0&siteid=0&campid=5338941691&customid=&toolid=10001&mkevt=1, which has a picture with J33565-001 in the marking and it's 12-pin. The J33565-xxx is the correct TPM for S2600ST.
Ragulan_Intel
Miyconst
Hi Ragulan and thank you for the answer but unfortunately, it does not help me either.
1. I do understand that AXXTPMENC8 is a 12-pin module according to the updated documentation, the problem is that there is also a 14-pin module and non of the authorized Intel retailers I contacted, know about the 12-pin version.
2. Do I understand you correctly that Intel does not have documentation for the Intel made products?
3. Thank you for the link, the eBay seller says that it's just a stock picture and they don't know whether the module is 12-pin or 14-pin because it's shipped from a remote warehouse.
Here are more links of 14-pin AXXTPMENC8 on sale:
https://www.computersalg.se/i/20997392/intel-axxtpmenc8-trusted-platform-modules-tpm-er
https://www.eetgroup.com/en-ie/axxtpmenc8-intel-axxtpmenc8-accessory-wid-w125145163
https://www.databyran.nu/produkter/65761
https://www.amazon.com/Intel-Trusted-Platform-Module-AXXTPMENC8/dp/B07JVPJ9T8
Subhashish
Hi Miyconst,
Greetings!
Regarding your query "PDF file with the pinout specification of the 12-pin version of the AXXTPMENC8 TPM 2.0 module" , we have checked this internally and got the update from engineering that we do not have a document for this module with PIN layout or any other specifications.
Subhashish_Intel.
Miyconst
I find it hard to believe that such a large corporation as Intel does not have specifications and/or documentation for its own products. If you, as an Intel employee, confirm that there is no documentation for AXXTPMENC8 module, I have no other option but to accept that Intel's customer support is simply incompetent, Intel sells products without any documentation, and I have to seek help elsewhere.
MACM
Hi Miyconst,
I would like to extend my sincerest apologies for the inconvenience and frustration you have experienced regarding the documentation for the AXXTPMENC8 module.
I understand how critical this information is for you, and we have checked this internally but could not find.
Ali
