AXXRPCM2
VMikh
Hi
What is the shelf life of AXXRPCM2?
How to find out the date of manufacture of the battery AXXRPCM2?
i connect AXXRPCM2 to SRCSAS 18E, in logs:
Controller ID: 0 Battery Not Present
Сontroller ID: 0 BBU disabled; changing WB logical drives to WT, Forced WB VDs are not affected
thanks in advanced
Hello mfmarya,
Hope you are doing fine,
You can access our web site "ARK" and search for the product.
As you can see in this https://ark.intel.com/products/49602/Intel-RAID-Smart-Battery-AXXRPCM2 link product launch date was from the first quarter of 2010 and it is discontinued since 2011 so, we recommend you to replace the battery.
Charlie_Intel
VMikh
yes, I already replaced battery on new one.
and this log after battery replacement:
Hello mfmarya,
Please verify that the battery is fine and can you share the TTY logs from the RAID Web console?
Also, can you try to update the RAID Controller firmware?
Charlie_Intel
VMikh
hi
how can i verify that the battery is fine?
i had replaced several batteries, which was buying about 2 years ago.
results the same - battery not present
firmware package version 7.0.1-0075
firmware version 1.12.280-0826
the log is in "attach"
Hello mfmarya,
Well actually I doubt that a battery with 2 years without use can maintain his integrity but, we could try performing the RAID controller firmware update and see if that works.
We were checking the logs and shows that as soon the RAID controller tries to charge, the battery denies it so, we can determinate that it is battery issues.
Charlie_Intel
VMikh
thanks.
Could you provide actual firmware (or link on it) to update, please?
If update don't help me, I'll try to buy new battery.
Hello mfmarya,
Sure, this is the correcthttps://downloadcenter.intel.com/download/19008/?product=22778 link to download the firmware.
Please, do not forget to check the Read Me (txt).
Charlie_Intel
VMikh
you give me link to firmware that's is already installing on server((
Flash package = 7.0.1-0075
Firmware Version = 1.12.280-0826
solution is to buy a new battery?
Hello mfmarya,
That is correct you should think about replacing the battery.
Charlie_Intel
Hello mfmarya,
We are wondering if you have further questions?
Charlie_Intel
VMikh
hi
no, thank you
I'll try to buy new battery and install it
Hello mfmarya,
Perfect.
You are welcome.
Charlie_Intel
