CATERR problem with S2600GZ
AZaka
I'm having a problem booting up my S2600GZ machine. When I plug the power, it starts on its own, and keeps rebooting. Even the BMC console is not functioning. I tried upgrading the firmware, using the BIOS Recovery jumper. It still gets stuck in the POST. The CATERR LED is always on.
I managed to get the bmc console running by removing the CMOS battery, and doing a power cycle, and I extracted the log file (attached).
I tried to:
  • power cycle the server several times.
  • removing the RAM completely/replacing them with different ones.
  • replacing the processors (2 X E5-2670 v2) with different ones.
But I always ended up with the same results. What am I missing here? what can be the problem?
KNatt
Hi Zakaria,
Is this a new integration? If yes, do have a Non-V2 processor available?
If you have a Non-V2 processor, boot the server with one processor and 2 memory modules(A1, B1), check if its restarting. If not, update the firmware to the latest and then connect a V2 processor.
I would also recommend you to try clearing the CMOS using the jumper. refer http://download.intel.com/support/motherboards/server/sb/g24881004_s2600gzgl_tps_r1_1.pdf http://download.intel.com/support/motherboards/server/sb/g24881004_s2600gzgl_tps_r1_1.pdf. Refer page: 5 for jumper location and 96 for procedure.
Kunal
AZaka
Hello Natta,
Thanks for replying. This is not a new integration. It was working flawlessly for 8 months, and suddenly crashed. I tried a Sandy Bridge processor (E5-2670), with the same results.
I also tried clearing the cmos, but in vain.
KNatt
I see. This seems to be an issue with the board and may need a replacement. One of the troubleshooting is to check without the memory modules connected. Power on the system without the memory modules and check if the system still reboots.It should give you 3 beeps without memory and the system should keep running without display. If it still reboots, try changing the power supply to a 700/750 watt[if available] to isolate the issue. If unavailable or if the issue persists, you should contact Intel customer support for replacement with the serial number of the product.Intel customer support: http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
AZaka
Thanks. I think I'll contact Intel for replacement.
