CELO TEST OF I350-AM2
jayhsu
After onboard lan (I350-AM2) celo test, linking 10m speed show fail
But i can connect to the internet on 10m/100m/1G ok.
Have idea what cause the test failed?
10. PCIE_slot1: Riser Card:
a. SLOT1: E1G44HT/Intel Ethernet Server Adaper,Intel(R) 82580,1G,Quad Port,Copper PCIE*4 LAN Card (IN26309*1)
b. SLOT2: Intel / I350-T2 / I350T2G1P20 / Intel Ethernet Server Adapter I350-T2 -Network adapter - PCI Express 2.1 (x4) low profile - 10Mb LAN, 100Mb LAN, Gigabit LAN -10Base-T, 100Base-TX, 1000Base-T RJ45 Copper (IN25109*1)
c. SLOT3: E1G42HTG1P20 / N8104-145 / IntelR Ethernet Server Adapter I340-T2 / 1000BASE-T 2ch LAN PCI-Express(x4) (NEC0409*1)
11. PCIE_slot2: Riser Card:
a. SLOT1: 82572GI/881983/Intel Pro/1000PT Server Adapter PCIEx1 (NEC No:N8104-126) For 9197 / LAN Card / NEC (IN25909*1)
b. SLOT2: N8104-131 / PCI-E 2.0 x8, 2xSFP+ 10G CNA Card (2ch) (NEC3709*1)
c. SLOT3: Intel Gigabit ET Dual Port Server Adapter/E1G42ETBLK/PCI Express 2.0 x4 (IN26409*1)
12. PCIE_slot3: Riser Card:
a. SLOT1:N8104-133 / 1000BASE-T Adapter(4ch) (BRO0809*1)
b. SLOT2:JL82576EB ES/Intel Protville-QT Gigabit ET Quad Port Server Adapter (IN23613*1)
AdrianM_Intel
Hello jayhsu,
To better assist you, can you please let us know more details:
  • What is the model of the server where the ethernet adapter is embedded?
  • Can you please share with us the link to the tool being used and the steps?
  • Was it working before or is this the first time running the tool?
  • Is this the only issue with the adapter (Test)? Does it work fine?
Adrian M.
AdrianM_Intel
Hello jayhsu,
Let me know if you need more assistance.
Adrian M.
AdrianM_Intel
Hello jayhsu,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Adrian M.
jayhsu
I am sorry for the late reply.
AMD platform, and use I350 on board.
Resource & Design Center Sign In (intel.com)
Step: celoe.efi  /sendresp 1 2  /stopfail  /loop 10
No, this was the first time.
Tested with OCP I350 card is okay.
