5172 讨论
CPU Upgrade E5-2640 to E5-2650 V2
PSchw4
初学者
4,651 次查看
Hi guys,
i need help. We have the intel mainboard S2600GZ and our supplier says to us, that we need the BIOS Version 01.01.1002 for the CPU Upgrade. On the Intel Download Site i can't find this Version of BIOS. By other Version the server show no screen and no BIOS. The server starts only with E5-2640 CPU by each BIOS Version of the Intel Site. Have anyone this special Version?
Thanks!
0 项奖励
12 回复数
AlHill
超级用户
3,199 次查看
I found this: https://downloadcenter.intel.com/download/27786/?product=56253 Download Firmware Update Package Update for EFI Intel® Server Boards and Intel® Server Systems Based on Intel® 60X Chips…
Doc
0 项奖励
PSchw4
初学者
3,199 次查看
Unfortunately it doesn't help.
0 项奖励
AlHill
超级用户
3,199 次查看
One of the Intel support engineers will have to assist you.
Doc
0 项奖励
员工
3,199 次查看
Hello Elmundo9,
Could you please share your board's sysinfo logs in order to further diagnose how to assist you with your inquiry?
Thank you,
FranklinS._Intel.
0 项奖励
PSchw4
初学者
3,199 次查看
Hello FranklinS._Intel,
in the Syslogs i don't find any information of an error. Maybe it's up to the revision of the motherboard for this error. Can you tell me what revision i have?
The P/N is DA0S6GMB8C1 Rev C. My suppliers says that i need rev 2.1 for the Ivy Bridge CPUs. On a BIOS Chip is S6G BIOS CS BD5B Rev 1.02.0005.
When i have the rev 1.02 than i buy Sandy Bridge CPUs with 8 Cores. No problem.
Philippe
0 项奖励
员工
3,199 次查看
Hello Elmundo9,
Nomrally we will recoomend for you to use the latest version available of the BIOS. We wanted you to share your system logs so that we can check what software version different components of your hardware are running on. In that way, we could help you find out which update path is best for you. Here is a link to the system information retrieval utility https://downloadcenter.intel.com/download/26991/System-Information-Retrieval-Utility-SysInfo-?v=t https://downloadcenter.intel.com/download/26991/System-Information-Retrieval-Utility-SysInfo-?v=t
Thank you,
FranklinS._Intel
0 项奖励
员工
3,199 次查看
Hello Elmundo9,
Were you able to use the system information retrieval utility? Let us know if you need additional help?
Thank you,
FranklinS._Intel
0 项奖励
PSchw4
初学者
3,199 次查看
here are your Information that you need. Thanks
Best regards
Elmundo9
0 项奖励
员工
3,199 次查看
Hi Elmundo9,
After checking your sysinfo_log we can see that you can simply upgrade to the latest version by using the software package located at https://downloadcenter.intel.com/downloads/eula/26962/Intel-Server-Board-S2600GZ-GL-Firmware-Update-Package-for-Extensible-Firmware-Interface-EFI-?httpDown=https://downloadmirror.intel.com/26962/eng/S2600GZ_GL_EFI_BIOS02060006_ME020107328_BMC0128r10603_FRUSDR114.zip
Follow the Standard Update Procedure from the embedded EFI Shell explained in the Read Me (txt) file.
Thank you,
FranklinS._Intel
0 项奖励
员工
3,199 次查看
Hi Elmundo9,
Were you able to upgrade your BIOS. Let us know if you need any additional help.
Thank you,
FranklinS._Intel
0 项奖励
PSchw4
初学者
3,199 次查看
Hi FranklinS._Intel,
i tested with every BIOS but it doesn't work. Finally i have choose another CPU combination. Now works with 2 Intel Xeon E5-2670. Thanks for your help.
Thank you,
FranklinS._Intel
0 项奖励
员工
3,199 次查看
Hi Elmundo9,
Glad to hear you worked it out that way at least. We are sorry to hear that the initial approach did not give the expected results.
FranklinS._Intel
0 项奖励
回复
