5173 Discussions
Cannot update firmware on DC P3600
SPigg
c:\isdct>isdct load -intelssd 0
WARNING! You have selected to update the drives firmware!
Proceed with the update? (Y|N): y
Updating firmware...
- Intel SSD DC P3600 Series PHMD6525000K2P0YGN -
Status : Please contact your Intel representative about firmware update for this drive.
c:\isdct>
c:\isdct>isdct show -a -intelssd 0
AggregationThreshold : 0
AggregationTime : 0
ArbitrationBurst : 0
BusType : 17
CoalescingDisable : 1
ControllerCompatibleIDs : PCI\\VEN_8086&DEV_0953&REV_01PCI\\VEN_8086&DEV_0953PCI\\VEN_8086&CC_010802PCI\\VEN_8086&CC_0108PCI\\VEN_8086PCI\\CC_010802&DT_0PCI\\CC_010802PCI\\CC_0108&DT_0PCI\\CC_0108
ControllerDescription : @oem9.inf,%pci\\ven_8086&dev_0953.devicedesc%;Intel(R) Solid-State Drive P3700/P3600/P3500/P3520/750 Series
ControllerID : PCI\\VEN_8086&DEV_0953&SUBSYS_00D98086&REV_01\\55CD2E414D5D886E00
ControllerIDEMode : False
ControllerManufacturer : @oem9.inf,%intel%;Intel
ControllerService : IaNVMe
DevicePath : \\\\.\\PHYSICALDRIVE2
DeviceStatus : Healthy
DirectivesSupported : False
DownloadMicrocodePossible : True
DriverDescription : Intel(R) Solid-State Drive P3700/P3600/P3500/P3520/750 Series
DriverMajorVersion : 4
DriverManufacturer : Intel
DriverMinorVersion : 2
DriverVersion : 4.2.0.1002
DynamicMMIOEnabled : The selected drive does not support this feature.
EndToEndDataProtCapabilities : 17
EnduranceAnalyzer : Media Workload Indicators have reset values. Run 60+ minute workload prior to running the endurance analyzer.
Firmware : 8DV1DP05
FirmwareUpdateAvailable : Please contact your Intel representative about firmware update for this drive.
FormatNVMCryptoEraseSupported : True
FormatNVMSupported : True
HighPriorityWeightArbitration : 0
IOCompletionQueuesRequested : 30
IOSubmissionQueuesRequested : 30
Index : 0
Intel : True
IntelGen3SATA : False
IntelNVMe : True
InterruptVector : 0
IsDualPort : False
LBAFormat : 0
LatencyTrackingEnabled : False
LowPriorityWeightArbitration : 0
Lun : 0
MaximumLBA : 3907029167
MediumPriorityWeightArbitration : 0
MetadataSetting : 0
MetadataSize : 0
ModelNumber : INTEL SSDPE2ME020T4D SFF NVME 2000GB
NVMeControllerID : 0
NVMeMajorVersion : 1
NVMeMinorVersion : 0
NVMePowerState : 0
NVMeTertiaryVersion : 0
NamespaceId : 1
NamespaceManagementSupported : False
NativeMaxLBA : 3907029167
NumErrorLogPageEntries : 63
NumLBAFormats : 6
NumberOfNamespacesSupported : 1
OEM : Dell
OpalState : Unsupported
PLITestTimeInterval : The selected drive does not support this feature.
PNPString : SCSI\\DISK&VEN_NVME&PROD_INTEL_SSDPE2ME02\\000000
PathID : 0
PhyConfig : The selected drive does not support this feature.
PhySpeed : The selected drive does not support this feature.
PhysicalSectorSize : The selected drive does not support this feature.
PhysicalSize : 2000398934016
PowerGovernorAveragePower : The desired feature is not supported.
PowerGovernorBurstPower : The desired feature is not supported.
PowerGovernorMode : 0
Product : Middledale
ProductFamily : Intel SSD DC P3600 Series
ProductProtocol : NVME
ProtectionInformation : 0
ProtectionInformationLocation : 0
ReadErrorRecoveryTimer : Device does not support this command set.
SCSIPortNumber : 2
SMARTEnabled : True
SMARTHealthCriticalWarningsConfiguration : 0
SMBusAddress : 128
SMI : False
SectorDataSize : 512
SectorSize : 512
SelfTestSupported : False
SerialNumber : PHMD6525000K2P0YGN
TCGSupported : False
TargetID : 0
TelemetryLogSupported : False
TempThreshold : 85
TemperatureLoggingInterval : The selected drive does not support this feature.
TimeLimitedErrorRecovery : 0
TrimSupported : True
Vendor : NVMe
VolatileWriteCacheEnabled : False
WriteAtomicityDisableNormal : 0
WriteCacheReorderingStateEnabled : The selected drive does not support this feature.
WriteCacheState : The selected drive does not support this feature.
WriteErrorRecoveryTimer : Device does not support this command set.
c:\isdct>
Using: Intel SSD Data Center Tool x64 -v3.0.16
JoseH_Intel
Hello SPigg, Thank you for joining the community. About this SSD issue could you tell if this is installed on a Data Center Block equipment? What method are you trying in order to update the firmware for this device? Could you share the hyperlink where you are downloading the firmware file? We will look forward for this information Regards Jose A. Intel Customer Support Technician Under Contract to Intel Corporation
SPigg
Hi Jose
It is installed on a HP DL380 Gen9 running Windows Server 2016.
I don't have any firmware files. I was under the impression (reading the manual and the how-to's online) that it downloads the firmware automatically.
thanks
JoseH_Intel
Hello SPigg, Thanks for the updates. I will transfer this thread to the SSD department so they could assist you better with the firmware installation. Regards Jose A. Intel Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
Hello SPigg, Thank you for contacting Intel® Memory & Storage Support. As we understand you need assistance with your Intel® SSD DC P3600 Series installed in your HP Proliant DL380 Gen 9 Server. In order to further assist you we will like you to provide us with the following information: • We will like to know if the Intel® SSD DC P3600 Series came included with your HP server. • We will like to know if you have tried to use the Intel® SSD Firmware Update Tool to update your SSD firmware (https://downloadcenter.intel.com/download/28174/Intel-SSD-Firmware-Update-Tool?product=80097) We will be looking forward to your reply. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
SPigg
  1. The drives were purchased separately from the server - you should be able to tell from the model number.
  2. The SSD Firmware Update Tool does not support the P3600 (as per the documentation on the Intel Website).
JosafathB_Intel
Hello SPigg, Thank you for contacting Intel® Memory & Storage Support. This is just a friendly reminder that your case remains open. Should you need our technical assistance please do not hesitate to contact us back. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
Hello SPigg, Thank you for having contacted Intel® Technical Support. I was reviewing your community post and we would like to know if you need further assistance or if we can close this case. We will be looking forward to your reply. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
Hello SPigg, Thank you for your reply. In order to further assist you we will like to know the following information: 1. We will like to know if you have tried to use the latest version of the Intel® SSD Data Center Tool (Intel® SSD DCT) to update your SSD firmware. https://downloadcenter.intel.com/download/28460/Intel-SSD-Data-Center-Tool-Intel-SSD-DCT-?product=87278 2. We will like to know how many units you have that are experiencing the same issue at the moment of trying to run a firmware update. 3. We will like to know if your drive is connected directly to the board or if the drives are connected to a backplane or a RAID controller. We will be looking forward to your reply including this information. Best regards, Josh B. Intel Customer Support Technician Under Contract to Intel Corporation
SPigg
sorry, but I don't think you know what this product is...
  1. Yes, the latest version is installed. In Explorer it just shows 2 bars in the circle and then won't continue any further without any error messages. In Chrome it just gives me the error "Oops, something went wrong while trying to scan. Please try again, or see our FAQs for help." There is however no help available for this error message. Windows Server 2016.
  2. We've got 4 units, all are experiencing the same issue.
  3. Based on the model number I gave you, it is impossible to be connected via RAID... NVME u.2 drives only have one possible way to connect to the main board.
JosafathB_Intel
Hello SPigg, Thank you for your reply. Based on the information you provided your server is an HP DL380 and your SSD model is an SSDPE2ME020T4D that is an OEM drive meaning that has been designed and modified to work with a specific firmware and hardware in your case a Dell* firmware. This being said, since you already tried using the latest version of our data center tool and you were not able to update the firmware of your drive, we advise you to contact Dell* for an updated version of the SSD firmware. Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
JosafathB_Intel
