5225 Discussions
Does VROC/VMD configuration retain after replacing battery on the motherboard?
Shigeyoshi_O_Intel
Does anyone know where VROC/VMD configuration set in BIOS setting GUI are store?
Is the information retained once after removing battery on the motherboard for replacement?
BR
Azhari_Intel
Hi Shigeyoshi_O_Intel,
Good day.
If I may offer an additional input here, after a VROC RAID volume is created, the RAID metadata is stored directly on the drives. Hence, it will not be affected by CMOS battery replacement.
Nonetheless, do let us know if you have any further queries, and also provide the system in use for further assistance.
Azhari_Intel
n_scott_pearson
How configuration is saved is actually dependent upon the motherboard design and its BIOS implementation, but, in general, BIOS store their configuration in a (non-volatile) flash component. Gone are the days where the (battery-backed) CMOS is used for BIOS Configuration storage. Bottom line, the BIOS Configuration will survive CMOS battery replacement.
Now, you might ask: What is the CMOS memory (still) used for? When the BIOS detects that the CMOS memory contents have been lost (i.e. battery failed), it uses this fact to indicate that the system should POST with a default set of configuration parameters. It also reports that the clock-time has been lost. Now, this defaulted-configuration POST is also expected to be used by the user to verify the BIOS configuration. This allows the battery removal act to be used to recover from Configuration-related problems.
[This is a non-BIOS Engineer's answer, so may be ~slightly~ inaccurate.]
Hope this helps,
Shigeyoshi_O_Intel
n_scott_pearson, Thank you so much for your answers!!
Vik3
Hello Shigeyoshi_O_Intel,
Thank you for posting on Intel Community. To assist you further, please provide the complete system details.
Vikas
intel.com/vroc
Azhari_Intel
Good day.
Azhari_Intel
Shigeyoshi_O_Intel
Sachinks
Thank you for your reply. We are happy to help!
Kindly let us know if you need any further assistance or if we can go ahead and close this thread.
Sachin KS
Shigeyoshi_O_Intel
Sachin,
Yes, we can close it now.
Sachinks
Thank you for the confirmation. We will proceed with the case closure.
Sachin KS
intel.com/vroc
