5180 Discussions
Error (8603): Secondary BIOS Checksum failed.
I have a MAXDATA server with an Intel motherboard SE7520JR2SCSID1.
When booting, I receive the following error: Error (8603): Secondary BIOS Checksum failed.
I've already changed the battery.
Does anyone know how I can fix it?
Thank you very much.
Edward_Z_Intel
Try a BIOS update.
DSilv11
Valued Contributor III
That system used a rolling BIOS meaning it contains 2 complete copies of BIOS incase one somehow gets corrupted.
Sounds like your secondary BIOS page is corrupt.
You may want to try re-flashing the BIOS. http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=11857&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=11857&lang=eng
If it is a random bit error, that should fix it.
