5173 Discussions
Error: Intel® RS2BL040 SAS Hardware RAID Driver for Linux
I have an error installing
Intel® SAS Hardware RAID Driver for Linux
on OpenSuse 11.4 x86_64.
I have installed
make
automake
gcc
kernel-source
kernel-devel
and
glibc-i18ndata-2.11.3-12.15.1.x86_64.rpm
qt3-3.3.8b-111.1.x86_64.rpm
lsb-4.0-12.1.x86_64.rpm
I have Downloaded latest driver from intel site:
# SAS Hardware RAID Driver for Linux
# File name: ir3_Linux_drv-v06.12-1.zip
# Version: 6.12
# Date: 12/15/2011
rpm -ivh dkms-2.0.22.0-1.noarch.rpm
[OK]
rpm -ivh ir3_sas-v00.00.06.12-1.noarch.rpm
Preparing... # [100%]
1:megaraid_sas # [100%]
Loading tarball for module: megaraid_sas / version: v00.00.06.12
Loading /usr/src/megaraid_sas-v00.00.06.12...
Creating /var/lib/dkms/megaraid_sas/v00.00.06.12/source symlink...
DKMS: ldtarball Completed.
Kernel preparation unnecessary for this kernel. Skipping...
Building module:
cleaning build area....
make KERNELRELEASE=2.6.37.1-1.2-default -C /lib/modules/2.6.37.1-1.2-default/build SUBDIRS=/var/lib/dkms/megaraid_sas/v00.00.06.12/build modules....(bad exit status: 2)
Error! Bad return status for module build on kernel: 2.6.37.1-1.2-default (x86_64)
Consult the make.log in the build directory /var/lib/dkms/megaraid_sas/v00.00.06.12/build/ for more information. 0 0
Error! Could not locate megaraid_sas.ko for module megaraid_sas in the DKMS tree.
You must run a dkms build for kernel 2.6.37.1-1.2-default (x86_64) first.
vi /var/lib/dkms/megaraid_sas/v00.00.06.12/build/make.log
DKMS make.log for megaraid_sas-v00.00.06.12 for kernel 2.6.37.1-1.2-default (x86_64)
Thu Jan 12 15:42:30 CET 2012
make: Entering directory `/usr/src/linux-2.6.37.1-1.2-obj/x86_64/default'
make -C ../../../linux-2.6.37.1-1.2 O=/usr/src/linux-2.6.37.1-1.2-obj/x86_64/default/. modules
CC [M] /var/lib/dkms/megaraid_sas/v00.00.06.12/build/megaraid_sas_base.o
/var/lib/dkms/megaraid_sas/v00.00.06.12/build/megaraid_sas_base.c:3233:2: warning: initialization from incompatible pointer type
/var/lib/dkms/megaraid_sas/v00.00.06.12/build/megaraid_sas_base.c:5195:16: error: unknown field âownerâ specified in initializer
/var/lib/dkms/megaraid_sas/v00.00.06.12/build/megaraid_sas_base.c:5195:16: warning: excess elements in struct initializer
/var/lib/dkms/megaraid_sas/v00.00.06.12/build/megaraid_sas_base.c:5195:16: warning: (near initialization for âsysfs_max_sectors_attr.attrâ)
make[3]: *** [/var/lib/dkms/megaraid_sas/v00.00.06.12/build/megaraid_sas_base.o] Error 1
make[2]: *** [_module_/var/lib/dkms/megaraid_sas/v00.00.06.12/build] Error 2
make[1]: *** [sub-make] Error 2
make: *** [all] Error 2
make: Leaving directory `/usr/src/linux-2.6.37.1-1.2-obj/x86_64/default'
Bartolini,
From the readme I see:
Below instruction includes how to manually update driver.
I. Installation
While installing OpenServer 6/UnixWare 7 be sure to insert the megasas Driver Supplement media before any HBA drivers supplied with your media kit.
You can find the complete readme here:
http://downloadmirror.intel.com/18778/eng/ir3_SCO_DRV_v4.05_readme.txt http://downloadmirror.intel.com/18778/eng/ir3_SCO_DRV_v4.05_readme.txt
You might want to verify if your OS version is supported by the latest driver.
John
But my distro is a Linux OpenSuse 11.4....
I have downloaded the latest firmware From download.intel.com
# Version: 6.12
# Date: 12/15/2011
Sorry about the distro mix up. Looking at the specific drivers we have, we show SuSE* Linux Enterprise Server 11.0. I don't know about cross compatibility of that driver with your OpenSuse 11.4.
However, I Googled "Could not locate megaraid_sas.ko for module megaraid_sas in the DKMS" and there were a number of problem reports and subsequent solutions. Give that a try and see if that helps.
John
I think there is a problem with kernel version.
OpenSuse 11.2 kernel 2.6.31.5-0.1.1
OpenSuse 11.3 kernel 2.6.34-12.3
OpenSuse 11.4 kernel 2.6.37.1-1.2.2
On OpenSuse 11.2 and OpenSuse 11.3
the driver update run succesfully.
Running < rpm -ivh ir3_sas-v00.00.06.12-1.noarch.rpm >
on OpenSuse 11.4 the update fails
# Error On OpenSuse 11.4
Consult /var/lib/dkms/megaraid_sas/v00.00.06.12/build/make.log for more information.
Sat Jan 14 17:10:32 CET 2012
