Intel® Xeon® Processors, Data Center Products including boards, integrated systems, and RAID Storage
5169 Discusiones
GPU Max 1100 i915 [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
Tore
Novato
2.314 Vistas
Hi Intel GPU support,
   Ubuntu 22.04.4LTS w/ 5.15.0-107-generic and intel-i915-dkms 1.23.5.19.230406.21.5.17.0.1034
   Due to dependencies (MLNX OFED and BeeGFS), I need to run either 5.15.0-107 or linux-hwe 6.2.0-39.
  I'm concerned with a few errors in the syslog.  Should I be?  The boards seem to be working fine, although I haven't run anything heavy yet,.
[ 38.861442] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: Unknown Error Cause: 0x0
[ 38.868872] i915 0000:9a:00.0: [drm] GuC firmware i915/pvc_guc_70.6.5.bin version 70.6.5
[ 38.869738] i915 0000:9a:00.0: Memory Health Report: Error correction pending.
          Card needs to be reset.
          Error Cause: 0x1001
[38444.028279] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[38444.038056] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[38444.050926] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
Gfx Hardware:
# lspci -v |grep -A18 -i display
29:00.0 Display controller: Intel Corporation Ponte Vecchio XT (1 Tile) [Data Center GPU Max 1100] (rev 2f)
Subsystem: Intel Corporation Device 0000
Flags: bus master, fast devsel, latency 0, IRQ 646, NUMA node 2, IOMMU group 26
Memory at 213e3f000000 (64-bit, prefetchable) [size=16M]
Memory at 20b000000000 (64-bit, prefetchable) [size=64G]
Capabilities: [40] Vendor Specific Information: Len=0c <?>
Capabilities: [70] Express Endpoint, MSI 00
Capabilities: [ac] MSI: Enable+ Count=1/1 Maskable+ 64bit+
Capabilities: [d0] Power Management version 3
Capabilities: [100] Alternative Routing-ID Interpretation (ARI)
Capabilities: [110] Process Address Space ID (PASID)
Capabilities: [200] Null
Capabilities: [420] Physical Resizable BAR
Capabilities: [220] Virtual Resizable BAR
Capabilities: [320] Single Root I/O Virtualization (SR-IOV)
Capabilities: [400] Latency Tolerance Reporting
Kernel driver in use: i915
Kernel modules: i915
9a:00.0 Display controller: Intel Corporation Ponte Vecchio XT (1 Tile) [Data Center GPU Max 1100] (rev 2f)
Flags: bus master, fast devsel, latency 0, IRQ 713, NUMA node 4, IOMMU group 262
Memory at 23fe3f000000 (64-bit, prefetchable) [size=16M]
Memory at 237000000000 (64-bit, prefetchable) [size=64G]
The relevant part of boot log:
# dmesg | egrep -i -e "BOOT_|i915|drm|display|Card|Error Ca"
[ 0.000000] Command line: BOOT_IMAGE=images/default-image-u22.04.4LTS-rocm573-cu14u1/vmlinuz initrd=images/default-image-u22.04.4LTS-rocm573-cu14u1/initrd console=ttyS1,115200n8 rd.blacklist=nouveau rd.blacklist=radeon intel_iommu=on iommu=pt systemd.unified_cgroup_hierarchy=0 systemd.legacy_systemd_cgroup_controller systemd.gpt_auto=0 console=tty0 console=ttyS1,115200n8 console=tty0 ip=10.128.1.26:10.128.0.2:10.128.1.254:255.255.254.0 BOOTIF=01-7c-ff-ff-ff-ff-ff
[ 7.502301] tboot: non-0 tboot_addr but it is not of type E820_TYPE_RESERVED
[ 7.515580] Kernel command line: BOOT_IMAGE=images/default-image-u22.04.4LTS-rocm573-cu14u1/vmlinuz initrd=images/default-image-u22.04.4LTS-rocm573-cu14u1/initrd console=ttyS1,115200n8 rd.blacklist=nouveau rd.blacklist=radeon intel_iommu=on iommu=pt systemd.unified_cgroup_hierarchy=0 systemd.legacy_systemd_cgroup_controller systemd.gpt_auto=0 console=tty0 console=ttyS1,115200n8 console=tty0 ip=10.128.1.26:10.128.0.2:10.128.1.254:255.255.254.0 BOOTIF=01-7c-ff-ff-ff-ff-ff
[ 36.852219] platform eisa.0: EISA: Detected 0 cards
[ 37.665961] BOOT_IMAGE=images/default-image-u22.04.4LTS-rocm573-cu14u1/vmlinuz
[ 38.226992] Loading modules backported from I915-23.5.19
[ 38.226994] Backport generated by backports.git I915_23.5.19_PSB_230406.21
[ 38.254560] ast 0000:02:00.0: [drm] P2A bridge disabled, using default configuration
[ 38.254563] ast 0000:02:00.0: [drm] AST 2600 detected
[ 38.254566] ast 0000:02:00.0: [drm] Analog VGA only
[ 38.254568] ast 0000:02:00.0: [drm] dram MCLK=396 Mhz type=1 bus_width=16
[ 38.255891] [drm] Initialized ast 0.1.0 20120228 for 0000:02:00.0 on minor 0
[ 38.262415] fbcon: astdrmfb (fb0) is primary device
[ 38.272745] ast 0000:02:00.0: [drm] fb0: astdrmfb frame buffer device
[ 38.774914] [drm] I915 BACKPORTED INIT
[ 38.775132] i915 0000:29:00.0: enabling device (0140 -> 0142)
[ 38.775488] i915 0000:29:00.0: [drm] GT count: 1, enabled: 1
[ 38.775597] i915 0000:29:00.0: [drm] IAF available
[ 38.775931] i915 0000:29:00.0: [drm] IAF: IRQ base: 645 cnt: 1
[ 38.775933] i915 0000:29:00.0: [drm] IAF: [dpa 0x3e000000000-0x3ffffffffff]
[ 38.775956] i915 0000:29:00.0: [drm] VT-d active for gfx access
[ 38.775985] i915 0000:29:00.0: [drm] Using Transparent Hugepages
[ 38.776039] i915 0000:29:00.0: [drm] Local memory IO size: 0x0000000bff000000
[ 38.776041] i915 0000:29:00.0: [drm] Local memory available: 0x0000000bff000000
[ 38.780534] i915 0000:29:00.0: [drm] GuC firmware i915/pvc_guc_70.6.5.bin version 70.6.5
[ 38.793891] i915 0000:29:00.0: [drm] GuC submission enabled
[ 38.793893] i915 0000:29:00.0: [drm] GuC SLPC enabled
[ 38.794161] i915 0000:29:00.0: [drm] GuC RC: enabled
[ 38.809240] i915 0000:29:00.0: GT0: local0 bcs'6.0 clear bandwidth:80783 MB/s
[ 38.809480] i915 0000:29:00.0: [drm] IAF: mem_resource = [mem 0x213e3f291000-0x213e3f2d0fff]
[ 38.809584] [drm] Initialized i915 1.6.0 20201103 for 0000:29:00.0 on minor 1
[ 38.859887] i915 0000:9a:00.0: enabling device (0140 -> 0142)
[ 38.860489] i915 0000:9a:00.0: [drm] GT count: 1, enabled: 1
[ 38.860661] i915 0000:9a:00.0: [drm] IAF available
[ 38.861056] i915 0000:9a:00.0: [drm] IAF: IRQ base: 712 cnt: 1
[ 38.861064] i915 0000:9a:00.0: [drm] IAF: [dpa 0x0-0x1fffffffff]
[ 38.861128] i915 0000:9a:00.0: [drm] VT-d active for gfx access
[ 38.861213] i915 0000:9a:00.0: [drm] Using Transparent Hugepages
[ 38.861328] i915 0000:9a:00.0: [drm] Local memory IO size: 0x0000000bff000000
[ 38.861333] i915 0000:9a:00.0: [drm] Local memory available: 0x0000000bff000000
Error Cause: 0x1001
[ 38.881899] i915 0000:9a:00.0: [drm] GuC submission enabled
[ 38.881902] i915 0000:9a:00.0: [drm] GuC SLPC enabled
[ 38.882183] i915 0000:9a:00.0: [drm] GuC RC: enabled
[ 38.898193] i915 0000:9a:00.0: GT0: local0 bcs'8.0 clear bandwidth:80939 MB/s
[ 38.898518] i915 0000:9a:00.0: [drm] IAF: mem_resource = [mem 0x23fe3f291000-0x23fe3f2d0fff]
[ 38.898685] [drm] Initialized i915 1.6.0 20201103 for 0000:9a:00.0 on minor 2
[ 42.930549] [drm] amdgpu kernel modesetting enabled.
[ 42.930552] [drm] amdgpu version: 6.2.4
[ 42.930553] [drm] OS DRM version: 5.15.0
[ 126.268504] systemd[1]: Starting Load Kernel Module drm...
[ 126.305783] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 126.306364] systemd[1]: Finished Load Kernel Module drm.
[ 127.360854] [drm] I915 SPI BACKPORTED INIT
[ 127.365577] iaf i915.iaf.31: Probing i915.iaf.31, connection point for 0000:29:00.0, fabric_id 0x0001001f socket_id 0x1f, sd_cnt 1
[ 127.365948] i915 0000:29:00.0: [drm] IAF: registered fabric: 0x1001f
[ 127.366183] Creating 4 MTD partitions on "i915.spi.10496":
[ 127.366188] 0x000000000000-0x000000001000 : "i915.spi.10496.DESCRIPTOR"
[ 127.367262] iaf i915.iaf.0: Probing i915.iaf.0, connection point for 0000:9a:00.0, fabric_id 0x00010000 socket_id 0x1f, sd_cnt 1
[ 127.367304] i915 0000:9a:00.0: [drm] IAF: registered fabric: 0x10000
[ 127.369421] 0x000000001000-0x000000eee000 : "i915.spi.10496.GSC"
[ 127.373695] 0x000000eee000-0x000000efe000 : "i915.spi.10496.DAM"
[ 127.376832] 0x000000efe000-0x000001000000 : "i915.spi.10496.PSC"
[ 127.381133] [drm] I915 SPI BACKPORTED INIT
[ 127.383509] Creating 4 MTD partitions on "i915.spi.39424":
[ 127.383511] 0x000000000000-0x000000001000 : "i915.spi.39424.DESCRIPTOR"
[ 127.392536] 0x000000001000-0x000000eee000 : "i915.spi.39424.GSC"
[ 127.397506] 0x000000eee000-0x000000efe000 : "i915.spi.39424.DAM"
[ 127.403749] 0x000000efe000-0x000001000000 : "i915.spi.39424.PSC"
[ 127.570086] iaf i915.iaf.31: PSC [Intel(r) Corporation] [PVC AIC] version 77089 : 2022/08/30 01:38:14
[ 127.570121] iaf i915.iaf.0: PSC [Intel(r) Corporation] [PVC AIC] version 77089 : 2022/08/30 01:38:14
[ 128.010945] mei_iaf i915.mei-gscfi.10496-fe2af7a6-ef22-4b45-872f-176b0bbc8b43: bound i915.iaf.31 (ops bind_ops [iaf])
[ 128.011735] mei_iaf i915.mei-gscfi.39424-fe2af7a6-ef22-4b45-872f-176b0bbc8b43: bound i915.iaf.0 (ops bind_ops [iaf])
[ 130.033421] iaf i915.iaf.31: Firmware Version: 1.0.0.0.2306231257
[ 130.037508] iaf i915.iaf.0: Firmware Version: 1.0.0.0.2306231257
[38444.063685] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[38444.297844] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[38444.307586] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[38444.320457] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[38444.333196] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[38444.641568] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: Unknown Error Cause: 0xfc3
[38444.650909] i915 0000:9a:00.0: Memory Health Report: Error correction pending.
Error Cause: 0x1001
[38446.576214] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[38446.585960] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[38446.598827] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[38446.611574] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[38446.902802] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[38446.912545] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[38446.925413] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[38446.938164] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[38449.165617] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[38449.175358] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[38449.188223] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[38449.200975] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[38449.471474] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[38449.481770] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[38449.495833] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[38449.509187] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[38451.650253] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[38451.660647] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[38451.674789] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[38451.688186] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[38451.697921] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[38451.708307] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[38451.722588] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[38451.736064] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[38452.003860] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[38452.014319] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[38452.028711] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[38452.042229] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[38454.250021] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[38454.260527] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[38454.274894] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[38454.288403] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[38454.556985] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[38454.567474] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[38454.581840] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[38454.595357] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[38456.783512] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[38456.794019] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[38456.808441] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[38456.821976] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[38456.831823] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[38456.842320] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[38456.856745] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[38456.870276] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[38457.138619] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[38457.149132] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[38457.163575] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[38457.177125] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[38457.186969] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[38457.197478] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[38457.211928] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[38457.225448] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[80758.760044] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[80758.771009] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[80758.785756] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[80758.799354] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[80759.068481] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[80759.079002] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[80759.093421] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[80759.106958] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[80759.116835] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[80759.127327] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[80759.141774] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[80759.155321] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[80761.372774] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[80761.383361] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[80761.397853] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[80761.411399] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[80761.678626] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[80761.689133] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[80761.703565] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[80761.717106] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[80761.726971] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[80761.737494] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[80761.751939] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[80761.765475] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[80763.944035] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[80763.954573] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[80763.969015] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[80763.982556] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[80764.246974] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[80764.257470] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[80764.271885] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[80764.285426] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[80764.295268] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[80764.305801] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[80764.320226] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[80764.333772] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[80766.507532] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[80766.518146] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[80766.532655] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[80766.546219] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[80766.556078] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[80766.566563] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[80766.581013] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[80766.594564] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[80766.833280] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[80766.843792] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[80766.858228] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[80766.871760] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[80769.117662] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[80769.128186] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[80769.142610] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[80769.156141] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[80769.509054] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[80769.519570] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[80769.533985] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[80769.547516] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[80771.771871] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[80771.782385] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[80771.796818] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[80771.810351] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[80772.015519] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[80772.026029] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[80772.040457] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[80772.053991] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[80772.063845] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[80772.074372] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[80772.088794] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[80772.102335] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[80774.256582] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[80774.267101] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[80774.281528] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[80774.295076] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[80774.304929] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[80774.315407] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[80774.329827] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[80774.343374] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[80774.610117] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[80774.620648] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[80774.635079] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[80774.648612] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[80774.658466] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[80774.668945] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[80774.683370] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[80774.696903] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[80776.906622] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[80776.917249] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[80776.931760] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[80776.945322] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
[80777.212481] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC NONFATAL error
[80777.223004] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_MASTER_REG_NONFATAL:0x00000002
[80777.237442] i915 0000:9a:00.0: [drm] *ERROR* [Hardware Error]: GT0 detected SOC_GLOBAL_ERR_STAT_SLAVE_REG_NONFATAL:0x00010000
[80777.250975] i915 0000:9a:00.0: [drm] *ERROR* GT0 [INTERRUPT] UNKNOWN SOC NONFATAL error
Rgds,
ToreL
Etiquetas (1)
0 kudos
0 Respuestas
Responder
