5173 Discussions
Hi , I am installing windows server 2008 R2 on intel server r1000 and during installation it is giving the error that DVD/CD drive drivers interface not found , What is the issue?
TJave
Edward_Z_Intel
What kind of DVD/CD-ROM drive are you using? How is it connected to the server board?
Maybe the easiest way is to create a USB installation disk: http://www.microsoftstore.com/store/msusa/html/pbPage.Help_Win7_usbdvd_dwnTool http://www.microsoftstore.com/store/msusa/html/pbPage.Help_Win7_usbdvd_dwnTool. This tool works with Windows Server 2008 R2 as well.
TJave
we are using The CD-ROM that is built in the server , i try to use external harddrive but it didnot work.Can it be a issue of RAID drivers
Edward_Z_Intel
Which board/system exactly are you using?
TJave
i am using sever board s1200v3rp
Edward_Z_Intel
OK if you have configured onboard RAID you'll need to load driver during OS installation. Which onboard RAID are you using, ESRT2 or RSTe?
TJave
we have configured Raid 10 with embedded Raid controller utility,
Pl. send me the exact driver link.it will be very kind of u
Edward_Z_Intel
TJave
thanks a lot, my issue is resolved.Thank you very much.i realy appreciate it
