5182 Discussions
How to determine BIOS revision board shipped with?
ALay1
I have an S5520UR that won't boot and I suspect that it might not have the required bios for use with a 5600 series processor. I can't even get into the bios to confirm this though. How can I determine which bios revision was shipped on the board based on the serial number or PBA?
David_A_Intel
The unit usually has a letter "R" at the end of the product code indicating that this is the "refresh" version supporting Intel® Xeon® processor 5600 series.
As you noticed some of our 5600 series processors would require BIOS 45 as some other 5600 series would need BIOS 54.
You may also visit our https://qdms.intel.com/ Intel® Quality Document Management System which will provide information of the changes applied to your PBA.
You could reply to this thread with your PBA and I can look that up for you.
David_A_Intel
ALay1
Thanks! My PBA is E22554-753. I found PCN 111309 - 01 which indicates that the board shipped with BIOS 60, so I guess that's not my issue. I guess I'll need to continue troubleshooting to figure out what's wrong.
