I use Intel's dual server S2600CP2 and Windows Server 2008 R2 operating systems. When I set up boot from EFI, Intel Embedded Server RAID Technology 2 could not be found under the Advanced Tab in BIOS, which means I could not use Human Interface Infrastructure Configuration Utility, how should I solve the problem, I checked a lot of Intel's technical documentation, did not find helpful to me.
- 标记:
- RAID
链接已复制
Hi zk z,
I apologize for the misunderstanding and confusion. The previous information was wrong.
Please make sure to have the latest BIOS installed on the server. If you already do so, follow the below steps:
- Go to the Advanced menu and select Mass Storage Controller Configuration:
- Select SATA Port Configuration:
- Change the AHCI Capable SATA Controller from the AHCI (default) option to RAID Mode:
- In the AHCI Capable RAID Options, make sure that INTEL® ESRT2 (LSI*) is selected:
- Press the Escape key until you get back to the Main Menu, and then select the Boot Maintenance Manager:
- Go to the Advanced Boot Options:
- In the Boot Mode menu, select the Legacy option and press Enter to change it UEFI:
- Press F10 and save the changes. The system then reboots.
Please let me know your results.
Jeremiah A.
Intel(R) Technical Support.
Hi zk z,
Thank you for you update.
Can you please confirm if can perform the following steps, and indicate the outcome?
- Boot the computer and press the F2 key to start the BIOS setup utility during start.
- When the initial window appears, select Setup Menu and press Enter.
- The Setup Menu appears.
- Highlight Advanced and press Enter.
- Highlight PCI Configuration and press Enter.
- Highlight UEFI Option ROM Control and press Enter.
- Use the arrow keys to highlight the controller under the Storage Controller selection you want to configure and press Enter.
Jeremiah A.
I checked into a document about Human Interface (HII) and I found the following: Please check attached image. Please follow the instructions stated in the image and let me know your results. You can also confirm this information in Topic 3: Human Interface Infrastructure Configuration at the following https://www.intel.com/content/dam/support/us/en/documents/server-products/raid-products/ESRT2_Software_UG.pdf link.
Jeremiah A.
I have read this document, I just follow this document to operate, the screenshot is the result of the operation, I have tried all the ways, including the advice you gave me to upgrade the firmware of the motherboard, I now think is, Maybe S2600 this motherboard does not support the HII interface, but this you need to help me confirm.
Hi zk z,
I hope you are doing well today.
I apologize for the delay on my resolution.
According to Engineering the Intel(R) server board S2600CP2 does not have the feature HII CU available.
It looks like this feature is exclusively for Purley family servers (S2600BP, S2600WF, and S2600ST) only.
Please let me know if there is anything I can help you with.
Jeremiah A.
