Avisos
5186 Discusiones
Intel S5000PSL support for E5430 CPU ?
dshma
Principiante
9.608 Vistas
Hello!
I have 2x5110. LGA771 socket.
BIOS version: s5000.86B.15.00.0101 11/09/2010.
I bought and insert 2xE5430 lga771.
But i have errors in BIOS: 19A, 19F, 19A.
What can i do?
0 kudos
22 Respuestas
dshma
Principiante
1.104 Vistas
p.s. Intel-Server-Chassis-SC5400BRP
selview:
Num : 241
Time Stamp : 06/23/2018-15:41:46
Sensor Type & Number : System Firmware Progress # 0x06
Event Description : Informational event: System Firmware Progress sensor 6 reports Processor voltage mismatch detected.
Generator ID : SMI Handler (Channel # 00h)
Num : 242
Event Description : Informational event: System Firmware Progress sensor 6 Processor and chipset stepping configuration is unsupported.
Num : 243
Event Description : Informational event: System Firmware Progress sensor 6 reports Local Console component encountered an output error.
Empleados
1.104 Vistas
Hello inusr,
Hope you are doing fine.
As we told you before we are limited because we do not have the hardware for testing or recreating the issue in our lab.
We went as far as we could to help you with common troubleshoot steps with no success.
What we can do is refer you to this /community/tech/discontinued-products website where you can create a thread for your issue.
We apologize for the inconvenience.
Charlie_Intel
Responder
