5181 Discussions
Intel Speed Select Explanation (High Core vs Low Core and Profiles)
dclz
Dear all,
I'm writing to you because we are envisonning using the following CPU on a KVM cluster:
using Intel® Xeon® 6737P Processor.
I would need your help to properly understand the Intel Speed Select and High Priority core vs Low Proirity.
I'm reading the following document : https://www.intel.com/content/www/us/en/products/sku/242628/intel-xeon-6737p-processor-144m-cache-2-90-ghz/specifications.html
The following statment is my current understanding of this technology :
This processor has 2.9 GHz nomial frequeny (avg. High - Low fre?)
12 High priority running at 3 G and can be adjusted up to 4GHz
20 Low priority running at 2.8 GHz
The Intel Speed selctor can "boost" high priority core to 4 GHZ if enabled on demand
Tun off unused lower piroty.
Looking at the profiles there are thee :
+ Base
+ Profile 1
+ Profile 2
My question are;
- Is my statement correct ?
- What is the default out-of-the-box status with Intel Speed selector  and related frequencies across each cores ?
- What are the profiles  ?
- Regarding a KVM  hypervisor, what is the safest option to use and the best ?
Sincerely.
vish1
Hello dclz,
Greetings for the day!!
I wanted to share some clarification regarding the behavior of the Intel® Xeon® 6737P processor and how it utilizes Intel® Speed Select Technology (SST).
The Intel® Xeon® 6737P processor uses Speed Select Technology (SST) to dynamically assign cores as high-priority (HP) or low-priority (LP), with HP cores running at higher base and turbo frequencies and LP cores at lower, energy-efficient speeds. Default profiles vary slightly depending on the OEM’s BIOS (e.g., HPE, Dell, Lenovo) and software layers, offering flexibility to balance performance and power efficiency across different workloads.
For more details, you may refer to the following official Intel documentation:
If you have any specific questions or need further assistance for your platform, feel free to reach out we are happy to help.
Vishal Shet P
vish1
Hello dclz,
This is the first follow-up regarding the issue you reported to us.
We wanted to inquire whether you had the opportunity to review our previous email we provided.
Vishal Shet P
vish1
Hello dclz,
Greetings!!
This is the follow-up regarding the reported issue. We're committed to ensuring a swift resolution and would greatly appreciate any updates or additional information you can provide.
If we don't hear back from you soon, we'll assume the issue has been resolved and will proceed to close the case.
Vishal Shet P
