5168 Discussions
Intel Xeon E5-2697v3 SMD Capacitors
ACrisan
I recently got a Xeon E5-2697v3 and tried to delid it to direct die cool it for experimentation, however, as there was no previous attempts I found, I did not know how far to push and scraped some of the SMD capacitors on the PCB off. Is there a data sheet which can tell me the type of capacitors which fit in each of the positions around the die so I can order replacements to get it operational? The E5-2697v3 should be the HCC (high core count) die.
ArchieD_Intel
Hi ACrisan,
Thank you for reaching out to the Intel Community Forum. To provide you with the best support, I'm moving this to our dedicated forum for these specific issues, where our specialists can assist you more effectively.
Archie D.
Azhari_Intel
Hi ACrisan,
Good day to you!
The product Intel® Xeon® Processor E5-2697 has reached its End of Interactive Support (EOIS). Intel no longer provides technical assistance, but you can continue looking for help from other community users. We recommend you search for an answer to your inquiry in the available self-help resources at Support for Intel® Xeon® Processor E5-2697. More information about the EOIS status of this product is available at Changes in Customer Support and Servicing Updates for Select Intel® Processors.
Azhari_Intel
ACrisan
Hello Azhari,
I apologize, I did not know what section to post my question in. Thank you for the response, I knew the Haswell-EP line no longer receives support, but I thought that more so meant processor replacements and microcode updates. May I keep my question in the other forum section to see if any community users may know? I am not sure if anyone outside of Intel has the capacitor layout though, it is a pretty niche specification.
Sincerely,
Alexandru Crisan
