5182 Discussions
Is this a hardware problem: Machine Check Exception: 4 Bank 8: ba000000008000b0 L5638 CPU
1528639113 [Hardware Error]: CPU 0: Machine Check Exception: 4 Bank 8: ba000000008000b0
1528639113 [Hardware Error]: TSC 3ebd3306cc3d8
1528639113 [Hardware Error]: PROCESSOR 0:206c2 TIME 1528639113 SOCKET 0 APIC 0
1528639113 [Hardware Error]: Run the above through 'mcelog --ascii'
1528639113 [Hardware Error]: Machine check: Processor context corrupt
1528639113 Kernel panic - not syncing: Fatal Machine check
1528639113 Pid: 0, comm: swapper Tainted: P M --------------- 2.6.32-358.76.1.el6.x86_64 # 1
1528639113 Call Trace:
1528639113 <# MC> [] ? panic+0xa7/0x16f
1528639113 [] ? mce_panic+0x20f/0x230
1528639113 [] ? do_machine_check+0xa28/0xa70
1528639113 [] ? machine_check+0x1c/0x30
1528639113 [] ? poll_idle+0x42/0xb0
1528639113 <<EOE>> [] ? cpu_idle+0xb6/0x110
1528639113 [] ? start_secondary+0x2ac/0x2ef
1528639114
1528639114
1528639114 Copyright (C) 2010 Alcatel-Lucent..
1528639114 ...... BIOS Version: 1-2-2/1 ......
1528639114 ........ Starting Bono BIOS .......
1528639119 ....d-con drbd0: PingAck did not arrive in time.
ap1906:root > cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 44
model name : Intel(R) Xeon(R) CPU L5638 @ 2.00GHz
stepping : 2
cpu MHz : 1999.928
cache size : 12288 KB
physical id : 0
siblings : 6
core id : 0
cpu cores : 6
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 11
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 cx16 xtpr pdcm pcid dca sse4_1 sse4_2 popcnt aes lahf_lm arat epb dts tpr_shadow vnmi flexpriority ept vpid
bogomips : 3999.85
clflush size : 64
cache_alignment : 64
address sizes : 40 bits physical, 48 bits virtual
power management:
processor : 1
cpu family : 6
model : 44
stepping : 2
cpu MHz : 1999.928
physical id : 0
siblings : 6
core id : 1
cpu cores : 6
apicid : 2
initial apicid : 2
fpu : yes
fpu_exception : yes
cpuid level : 11
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 cx16 xtpr pdcm pcid dca sse4_1 sse4_2 popcnt aes lahf_lm arat dts tpr_shadow vnmi flexpriority ept vpid
bogomips : 3999.85
clflush size : 64
power management:
processor : 2
cpu family : 6
model : 44
stepping : 2
cpu MHz : 1999.928
physical id : 0
siblings : 6
core id : 2
cpu cores : 6
apicid : 4
initial apicid : 4
fpu : yes
fpu_exception : yes
cpuid level : 11
wp : yes
bogomips : 3999.85
clflush size : 64
power management:
processor : 3
cpu family : 6
model : 44
stepping : 2
cpu MHz : 1999.928
physical id : 0
siblings : 6
core id : 8
cpu cores : 6
apicid : 16
initial apicid : 16
fpu : yes
fpu_exception : yes
cpuid level : 11
wp : yes
bogomips : 3999.85
clflush size : 64
power management:
processor : 4
cpu family : 6
model : 44
stepping : 2
cpu MHz : 1999.928
physical id : 0
siblings : 6
core id : 9
cpu cores : 6
apicid : 18
initial apicid : 18
fpu : yes
fpu_exception : yes
cpuid level : 11
wp : yes
bogomips : 3999.85
clflush size : 64
address sizes...
Hi EJ_Franckowiak,
The error that you are getting seems the Central Processing Unit (CPU) has detected an error in the system or received an erroneous instruction from a system component.
The workaround for this issue is the following: Double check if your system manufacturer released a newer BIOS and drivers for your computer and update the system.
Intel has a tool to verify how the processor is working called: Intel® Processor Diagnostic Tool
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
It is a stress test and your processor is old now. The tool might work on your system.
Miguel C
Intel Customer Support
Hi EJ_Franckowiak,
I am following up your machine check error. In my previous email, I suggest you double check if newer BIOS and drivers were available at your system manufacturer. Additionally, to this troubleshooting, double check if all the memory modules are properly seated on the slots.
Miguel C
Hi EJ_Franckowiak,
I am following up on your last post, please let me know if I can help you with anything else.
Miguel C
